-   -   Attic unit installed wrong. (http://www.diychatroom.com/f17/attic-unit-installed-wrong-21052/)
olgzr 05-15-2008 08:29 PM
My son is buying a house that was renovated 5 years ago. The Attic unit is a vertical (closet type) unit that is installed in the attic horizontally, not vertically. It appears to be working correctly. Is this a problem or something to worry about? Or is this normal?
LawnGuyLandSparky 05-16-2008 10:54 AM
WTF is an "attic unit?"
olgzr 05-16-2008 11:54 AM
The "attic unit" is the part of the airconditioner that is installed in the attic. It contains the blower, blower motor, heating coil and the condenser. The other part goes outside. It contains the compressor. If the inside unit is designed to be installed in the wall or closet, it is positioned vertically. Units designed for an attic are designed to install horizontally.
Maintenance 6 05-16-2008 11:54 AM
Some companies made units that could be installed either way. The most important thing is that the pan is configured so that the condensate drains properly and does not pool inside the unit or does not carry over in the airstream and end up in the discharge duct work.
olgzr 05-16-2008 12:01 PM
Thanks, I will have to get the part number and manufacturers name next time that I am over at the house so I can contact the manufacturer to find out if this is a type that can be installed either way. I saw the fittings that are usually used to hook up drains, they were near the top but I did not look at the lower drain to see how it was hooked up.
MacRoadie 05-16-2008 02:37 PM
It's pretty common to see the condition you've described. I've seen literally hundreds of them.Your first reaction, on seeing the labels or badge running the wrong direction is that the unit was installed in the wrong orientation. As the earlier poster stated, it's very likely a model that can be installed in either manner., like these Carrier units.
http://farm3.static.flickr.com/2110/...2d23bb89_m.jpg
http://farm3.static.flickr.com/2142/...c12176ee_m.jpg
olgzr 05-16-2008 10:17 PM
Thanks, I'll check the next time I'm at the house.
