Attic Mounted AC Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2006, 10:48 AM   #1
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
I'm wanting to install Central Air in my 150 year old victorian home. I do have central heating, but was told by the previous owners that some heating and cooling people told them the duct work isn't sufficient for AC. I don't know much about heating and cooling, so does that make sense?
At any rate, I've heard about those units that can be installed in the attic and you just run some duct work through the ceiling and poof! you've got central air. (like it would be that simple) Does anybody know anything about this stuff and what I should look for?
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Old 03-08-2006, 12:21 AM   #2
747
registered
747's Avatar
Rewards Points: 534
I have no ideal. You need to ask Doc. But i'm not sure if he stops bye. If anyone would know he would.
747 is offline   Reply With Quote
Old 03-08-2006, 09:01 PM   #3
sub-contractor
Yes,
It is possible that the ductwork is undersized to get the proper airflow to install the proper sized air conditioning unit in your home. but I would call a real heating contractor to look at your system and give you a quote before taking the previos homeowners word.
Aceinstaller is offline   Reply With Quote
Old 03-08-2006, 11:44 PM   #4
Contractor
Rewards Points: 150
Yeah, I think that's the route I'll take. There's a sub I used to work with on new homes. I think I'll give him a call. Thanks for the advice.
Regards,
Ken Walker
Old 03-16-2006, 06:42 AM   #5
weinstall.ca
ductwork sizing
If i knew the size of duct that is existing i could help you out.
Here are a couple of examples.
You need approximately 400 cfm of air for every ton of ac.
2 tons = 2 x 400 = 800 cfm
Duct size for approximately 1 ton = ( 12 x * or ( 16 x 6)
duct size for approximately 2 tons ( 12 x 12 ) 0r ( 20 x 8)
depending on the square fotage of the home you coud put an ac to these sizes.
Let me know what happens
Allan Thorne
Clarkson Comfort Zone Heating and Air Conditioning Mississauga Ontario
weinstall.ca
allan is offline   Reply With Quote
Old 03-17-2006, 12:03 AM   #6
Contractor
Rewards Points: 150
I'm leaving for vacation tomorrow, when I get back I'm gonna head to the basement and take some measurements and I'll post back.
Regards,
Ken Walker
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 06:36 AM
Vent Hood CFM's wease Appliances 14 04-20-2012 08:00 AM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 05:21 AM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 01:41 AM
