Old 09-05-2009, 12:59 AM   #1
Attic Insulation question
I also have a 2 Story house in Dallas with a twist. It has 3 basically seperate attics. 1 over the bedrooms which are in a 2 downstairs, 2 upstairs config.
2nd attic is over the "no upstairs" portion of the home where the kitchen & dining rooms + garage are located.
Between these 2 attics is a sloped ceiling (goes from 20' to 24') that has perhaps 12" of space between the ceiling & roof. Unaccessible to man due to these limitations. I would est. this section is 42' X 27'.
This house has recently been re-roofed & now features ridge vents & new intake soffits. Insulation is original 1965 & minimal at best.
Question is how best to deal with this 12" portion that you cannot possibly crawl in?
nomad4137 is offline   Reply With Quote
Old 09-06-2009, 07:48 PM   #2
JohnH1's Avatar
You may be able to drill aprox 2" holes in the drywall celing every 2 to 4ft and blow in insulation. Unless this is a designed pathway for air to flow from one attic up and out the other. Then you won want to compleatly block the joist spaces up. Just an idea I am not a insulation person.
JohnH1 is offline   Reply With Quote
question about running romex in attic ceiling jayp Electrical 5 03-20-2009 02:06 PM
attic ventilation chutes question MadisonMan Building & Construction 1 11-20-2008 11:52 PM
un-vented attic insulation questions.... roadk Building & Construction 12 09-18-2008 07:54 AM
Attic Insulation Quote...what do you think? mitchel Roofing 15 08-06-2008 08:10 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
