Attic/HVAC Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 05:15 PM   #1
Smile
Attic/HVAC Issue
Okay, so I live in a 4 bedroom apt. with 5 people. Previously a roommate moved out and I moved into his room which is located (basically) in the attic. This room gets extremly hot even during the winter. From what I can tell the air duct for our central heating/cooling goes through here for the entire house. There are two on each end. And during the winter my roommates will have the heat at 70 which makes it somewhere around 80's and 90's. There is one small window on the far end of the room which I have place a small fan, and I have a big fan drawing air towards that fan. Is there anything at all I could do?
Joseph1334 is offline   Reply With Quote
Old 12-11-2010, 09:46 PM   #2
If you mean there are 4 ducts or registers, they're likely in the walls or the floor. Poor man say remove registers and stuff a towel or old tee shirt into opening where heat comes from. Shut down one at a time to see effect.
Alternately use a piece of tin or flashing to cover hole(s) completely or partially or some combination. This will make your roommates' rooms hotter too and the one controlling the thermostat may lower temp as well.
diyorpay is offline   Reply With Quote
Old 12-11-2010, 10:46 PM   #3
Thank you! My girlfriend told me about putting some sort of cloth into the vent but I was unsure if that was a fire hazard?
Old 12-12-2010, 08:10 AM   #4
Actually I just want to post, we messed around on a few things last night...woke up to a freezing room! We covered the vents and when that didnt seem to help we just put a bigger fan in front of the little hole to outside =P
Bathroom Remodel and Mold Issue jjump Remodeling 5 02-15-2010 12:56 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Lennox G21Q issue gotzapped HVAC 2 11-25-2008 02:28 AM
