Attic Gable Fan Install - HVAC - DIY Chatroom Home Improvement Forum
Old 04-23-2008, 03:11 PM   #1
Attic gable fan install
I'm going to put a fan in the little gable window in my attic. Do I need to block off the gable window at the other end of the attic?
mattmcl is offline   Reply With Quote
Old 04-23-2008, 04:21 PM   #2
RDS
Rewards Points: 150
I'm no pro but I'm pretty sure a pro would tell you quite the opposite -- that if you're going to vent, you also need an air intake of equal area in order to keep fresh air flowing into the attic, replacing what you're venting. (Though maybe if you have some *other* intake source, like soffit vents, it would be OK...)
RDS is offline   Reply With Quote
Old 04-23-2008, 10:26 PM   #3
coolmen's Avatar
dont cover it so to have fresh air intake. offten time soffet vents are not enough
coolmen is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 06:36 AM
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 01:55 PM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 11:50 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 01:41 AM
Leaking attic gable vents MoMo Roofing/Siding 2 04-02-2005 10:00 PM
