Attic Furnace Water Pump
I have a horizontal attic furnace with a pump to drain water when the a/c is on. Tthe pump has a plastic tube that carries the water to a 2nd floor drain. Sometimes the a/c compressor will not come on. It has come on when I have leveled the pump. Yesterday, the pump was level,but the compressor was still off. I shook the pump, manually forced all water down the tube, and the compressor came on. How can I fix this problem? Do I need a new pump or does it just need to be worked on? Can I fix it myself? Thanks.
