Old 08-11-2012, 03:07 PM   #1
attic fan thermostat missing
Hi all,
New member to the site and a new homeowner!
I live in a pretty hot area (during the summer) and have been in the attic a couple of times now to inspect the two gable attic fans that are installed on either end of the house. The fans are pretty old-school. Emerson Electric K55 models, both identical. (See the pics)
I've traced the wiring from the fan all the way back to the circuit breaker and there is no thermostat installed. However, there is a silver component on the rear of each attic fan that I suspect might be the thermostat. The attic fans are older, so I can't find any documentation for them online.
Can anyone tell me
1) is that silver component the thermostat?
2) are there places online where I can find documentation for these things?
3) what's the best way to test if the fans actually run?
Thanks much,
MB
mb0709 is offline   Reply With Quote
Old 08-11-2012, 03:15 PM   #2
looks like a close on a rise snap disk and yes if that is what it is it is most likely acting as a thermostat. don't know where to find info on that fan. I have personally seen one. What is the temp in the attic? It should run the fan i would think if above 110/120 degrees. a hair dryer should be able to put enough heat on the snap disk to bring it on if everything is working.
turnermech is offline   Reply With Quote
Old 08-11-2012, 03:53 PM   #3
biggles's Avatar
hold a candle below the disc should heat it up to run it then the candle will go out....
Old 08-11-2012, 05:42 PM   #4
I checked out snap disks and it does look very similar to what is on the fan right now. After it cools down a bit I'll head up there and do some poking around again. Maybe even the candle technique will be given a try. The temp up there is hot. Definitely feels over 110, but I haven't measured with a thermometer yet. Will let you know what I find!
Thanks for the information!
Old 08-11-2012, 05:50 PM   #5
Looks like some sort of motor overload to me , never seen one of them before. Good luck hope they work as mentioned.
COLDIRON is offline   Reply With Quote
Old 08-11-2012, 06:54 PM   #6
kmc
I got a replacement fan for $50 on amazon last year. Those things go bad from the dust and lack of lubing. I would bet it's toast by the looks of it.
kmc is offline   Reply With Quote
Problem Attic fan Thermostat Hennessy16 Electrical 5 06-23-2012 07:23 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Powered Attic Fan question spup345 Roofing 9 06-30-2008 09:10 PM
