Attic Fan Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 03:14 PM   #1
Hello,
I just installed a new attic fan in my attic. I have ridge vents but no soffits. The attic fan is attached to a window on the side of the attic. What is a good thermostat setting? The attic is insulated with roll bats in the floor joists. I live in charleston sc a very hot summer climate.
thanks
Dave
DToynk is offline   Reply With Quote
Old 06-02-2011, 03:42 PM   #2
Rewards Points: 1,552
I think most would say to add in soffit vents and get rid of the roof fan if that is what is meant by attic fan. But, I would think if you set it for 115 or so it would bring down the temp theoretically reducing the load on the ac system. You are fighting natural tendency of hot air to rise and exit the ridge vents by what you are planning.
See:
http://www.greenbuildingadvisor.com/...tilators-green
http://www.energystar.gov/index.cfm?...ic_ventilation
http://www.factsfacts.com/MyHomeRepair/ventilation.htm
The main point of most of these is: "Although attic ventilation has been shown to reduce attic air temperatures and cooling loads the only examination of powered attic ventilators has shown the electricity consumption of the ventilator fans to be greater than the savings in air conditioning energy (Burch et al., 1979)." Especially if attic is R19 or higher. Fixing air leakage from conditioned space into attic would be a great move to reduce costs if the attic space is negatively pressured (from gable fan running) and drawing conditioned air into the attic.
bob22 is offline   Reply With Quote
Old 06-09-2011, 11:27 AM   #3
Unfortunately soffit vents are not an option. My attic is only 1000 sq ft and I have a window on each side. Do you think if i keep both windows open will this be enough airflow with my ridge vents? Also if I try this I was just thinking of monitoring the temperature, so what would a decent temp in the attic be on a 90 degree day?
thanks
Dave
Old 06-09-2011, 11:48 AM   #4
Rewards Points: 150
I think most manufactures recommend attic fan t-stats to be 105 to 115
I have mine set at 105
alecmcmahon is offline   Reply With Quote
Old 06-09-2011, 01:36 PM   #5
HVAC Tech/Owner
Rewards Points: 604
With ridge vents I would be more inclined to have a fan in the windows blowing in.
Don't know why soffit vents are not an option but they make ridge vents work the best especially with some foil on the rafters.
Technow is offline   Reply With Quote
Old 06-10-2011, 03:11 AM   #6
i have a similar issue, i cant install soffet vents cause my attic is sectionated or compartmentalized, so even if i installed soffet vents the cool air wont reach the ridge vent. what should we doo???
josephthomas199 is offline   Reply With Quote
Tags
attic , attic fan , thermostat
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
Heat but no A/C with new thermostat myqhenry HVAC 15 05-30-2011 11:53 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Attic Frost cougar01 Building & Construction 5 01-28-2009 09:33 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
