Old 05-13-2009, 09:42 PM   #1
Attic fan question?
We have a small cape cod with a finished attic. A small part of the attic (about 8X10 feet) is unfinished storage. I'm looking to add an attic fan to lessen the amount of heat we have upstairs in the summer. It's extremely hot. In this situation, do we put the attic fan in the storage area, or would this not pull enough air from upstairs considering it's in an enclosed area? I cannot envision putting it in the finished attic space. Help?
k.kuenn is offline   Reply With Quote
Old 05-14-2009, 08:49 AM   #2
Attic fan question?
If the storage area is an enclosed space and you install the attic fan there, the fan will only ventilate the storage space, and this is only if you provide adequate free inlet area for air to enter the storage area and replace the air you are removing.
You may want to consider installing a quiet attic fan (with a guard below so people can't stick their hands into the fan) that pulls air directly from the finished space in your attic. When you run this fan, it is important to open windows so fresh air from outdoors is pulled in through the open windows, through the attic to the fan, then back outdoors.
Another alternative would be to install the fan above the storage space and put in grilles that allow air to freely travel from the finished space to the storage space. This would move the fan and associated noise away from the living space while still allowing the fan to pull air from the living space (if windows are open to let fresh air in).
stitch is offline   Reply With Quote
Old 05-14-2009, 09:03 AM   #3
the Musigician
DangerMouse's Avatar
Attic fan question?
personally, i'd go with a solar powered attic fan(s), the hotter it gets, the faster it/they blow(s)!
and the cost to run it/them is nice too!
if you let it breathe from gable to gable with the fans, they'll remove the heat just fine.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 05-14-2009, 12:47 PM   #4
An old Tradesmen
Attic fan question?
Becarefull of attic fans.
If the vents can't bring in as much air as the fan can move.
The fan will draw that air from where ever it can. Even if it has to draw it out of the house.
Old 05-22-2009, 11:38 PM   #5
Attic fan question?
Besides an attic fan would you recommend a different solution?
Old 05-23-2009, 12:17 AM   #6
An old Tradesmen
Attic fan question?
Turbines.
They won't put teh house into a negative pressure.
Old 05-25-2009, 03:05 PM   #7
Attic fan question?
Thank you! this helps, a LOT! I was googling the turbines to shop them and came up with another question. Is the combination of a ridge vent, turbine and soffit/edge vents appropriate? I would like to use all three.
Or is it the rule to use only one; either a ridge vent or turbine...not both?
Old 05-25-2009, 08:05 PM   #8
An old Tradesmen
Attic fan question?
Turbines without ridge works best.
The ridge could decrease the ability of the turbines.
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
AH In Extreme Cold Attic Question Home Air Direct HVAC 6 03-14-2009 10:02 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
Attic Venting/Insulating Question gregt848 Building & Construction 1 11-25-2007 03:33 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
