Attic Ductwork - Need Some Ideas - HVAC - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 09:28 AM   #1
Attic Ductwork - Need some ideas
Hi, I'm new and need some advice.
I recently replaced my attic airhandling unit due to its age and the mold/dust living in it etc.. The distribution system on the supply side is "radial" in that there are 4 10" flex trunks that feed into ductboard triangles with further split from there.
I Opted to replace the Ductboard supply and return boxes with lined metal boxes, and I would like to eliminate any ductboard remaining in the system.
What are my options in replacing the ductboard triangles? New ductboard triangles? galvyTri-Wyes? fabricate some Metal Triangles?
RustedBrit is offline   Reply With Quote
Old 03-17-2011, 10:05 AM   #2
Experienced
Jackofall1's Avatar
Hi and Welcome RustedBrit, to the best darn DIY'r site on the web.
A couple of pictures of the system you are trying to modify would be a great tool to assist in coming up with a qualified answer.
Mark
Old 03-17-2011, 01:02 PM   #3
Metal Wyes adding insulated wrap
Poppyloppy is offline   Reply With Quote
Old 03-17-2011, 03:05 PM   #4
An old Tradesmen
Rewards Points: 7,328
A little late now, but you should have used sheet metal and then wrapped it. Lined sheet metal can form mold as easily as duct board.
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 10:19 PM
Opinions/experience with Attic Breeze Solar Fan? matrixman Roofing/Siding 2 09-23-2010 11:59 AM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
