Old 11-09-2005, 12:51 PM   #1
Attic Condensation
I guess the dripping vents are a symptom of another problem, attic condensation. The roofing nails that penetrate have frozen drops of water on them, there are wet spots on the blown-in insulation, and the roof planking is covered with frost in places. What should I do to alleviate this?
billinak is offline   Reply With Quote
Old 11-09-2005, 02:29 PM   #2
Attic Condensation
I just read your other post that Mike answered.
How is your roof vented ? Any blockage ?
Scott_K is offline   Reply With Quote
Old 11-09-2005, 03:36 PM   #3
Attic Condensation
I just installed a ridge vent this summer, but I think the soffit vent are probably inadequate
Old 11-09-2005, 04:10 PM   #4
Attic Condensation
I just had a ridgevent installed earlier this year. It runs about 26'. The south soffit also runs 26', the north side of the house has about a 16' soffit run with a gable for the remaining run.
Maybe check out the roofing sub-forum. I remember reading/posting a few things about ridgevents this year. Just realized this is in the HVAC forum.
Old 11-09-2005, 07:18 PM   #5
Attic Condensation
I think you might be getting too much warm moist air into your attic. Any dryer vents bath vents etc should be vented to the outside. A drywall ceiling with paint should be a vapor barrier between living space and the attic. Any air leaks leaks? Are you noticing more condensate on the north side of the roof than the south side? North roofs are generally alot colder in my area and will show more condensation.HS.
K2eoj is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 17 09-06-2008 01:59 PM
Running Romex in the attic mdalli Electrical 7 07-06-2006 06:35 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 01:41 AM
attic condensation darren Roofing 11 01-24-2006 11:27 PM
