Old 04-29-2011, 06:29 PM   #1
Attic Air Handler - Hang vs Sitting
Which do you guys prefer and why?
Hanging the air handler in the attic of the roof joists, or sitting it on the ceiling joists?
alecmcmahon is offline   Reply With Quote
Old 04-29-2011, 06:49 PM   #2
From a service standpoint I like them hung from the rafters. I can work better standing up than I can sitting down and leaned over.
brandonmcginnis is offline   Reply With Quote
Old 04-29-2011, 10:36 PM   #3
either way.
hanging is probably more costly for sheetmetal install. you need real good vibration isolation if you hang it.
If you set it on the ceiling joist you can insulate below the aux pan. and set the unit in the pan.
if you have the height hanging is more comfortable to service.
Artco is offline   Reply With Quote
Old 04-30-2011, 01:02 AM   #4
Originally Posted by Artco View Post
either way.
I would figure it would be the opposite ( for vibrations ). I thought by getting it off the ceiling joists and hanging it off the roof trusses that it would cut down on any noise / vibration that might be heard through the living space.
Old 04-30-2011, 09:14 AM   #5
yes as long as you purchase and install good isolation hanger supports.
I have seen where threaded rod and angles lagged into roof joist with no vibration isolators caused the sounds of operation to be heard in the conditioned space.
Old 05-01-2011, 02:24 AM   #6
should i also be using rubber isolation pads if i decide to set it on the attic floor? I dont think i'll have enough headroom to hang.
Old 05-01-2011, 08:50 AM   #7
Yes, you should have an auxillary pan under the air handler for safety in case the unit condensate over flows along with a pan safety switch to shut the systm off.
You can also use styrofoam under the unit between the unit and the pan cut in lengths that support the air handler. The styrofoam will absorb a lot of noise.
Old 06-27-2011, 12:37 PM   #8
HVAC Tech/Owner
Originally Posted by Bill208;675030[URL="http://www.Quick-Sling.com"
[/URL] HVAC Hanging system Removed spam ad
Uhhhh, looks kind of hard to get the panels off that furnace....the RNC guys will love it.
Last edited by beenthere; 08-06-2011 at 05:25 PM. Reason: removed spam ad from quote
Technow is offline   Reply With Quote
Attic Foam Board Insulation JasonCA Roofing 3 10-07-2010 01:56 AM
moisture in attic rocky1charle Roofing 17 02-02-2010 06:10 PM
Excess moisture/condensation/frost in attic Fingers General Discussion 2 12-29-2009 11:38 PM
Frost in the Attic 295yards General Discussion 13 12-07-2009 05:27 PM
Attic moisture Carstonio Roofing 14 01-29-2009 12:35 PM
