-   -   Attic Air Handler - Hang vs Sitting (http://www.diychatroom.com/f17/attic-air-handler-hang-vs-sitting-103129/)
alecmcmahon 04-29-2011 05:29 PM
Which do you guys prefer and why?
Hanging the air handler in the attic of the roof joists, or sitting it on the ceiling joists?
brandonmcginnis 04-29-2011 05:49 PM
From a service standpoint I like them hung from the rafters. I can work better standing up than I can sitting down and leaned over.
Artco 04-29-2011 09:36 PM
either way.
hanging is probably more costly for sheetmetal install. you need real good vibration isolation if you hang it.
If you set it on the ceiling joist you can insulate below the aux pan. and set the unit in the pan.
if you have the height hanging is more comfortable to service.
alecmcmahon 04-30-2011 12:02 AM
Originally Posted by Artco (Post 639342)
either way.
I would figure it would be the opposite ( for vibrations ). I thought by getting it off the ceiling joists and hanging it off the roof trusses that it would cut down on any noise / vibration that might be heard through the living space.
Artco 04-30-2011 08:14 AM
yes as long as you purchase and install good isolation hanger supports.
I have seen where threaded rod and angles lagged into roof joist with no vibration isolators caused the sounds of operation to be heard in the conditioned space.
alecmcmahon 05-01-2011 01:24 AM
should i also be using rubber isolation pads if i decide to set it on the attic floor? I dont think i'll have enough headroom to hang.
Artco 05-01-2011 07:50 AM
Yes, you should have an auxillary pan under the air handler for safety in case the unit condensate over flows along with a pan safety switch to shut the systm off.
You can also use styrofoam under the unit between the unit and the pan cut in lengths that support the air handler. The styrofoam will absorb a lot of noise.
Technow 06-27-2011 11:37 AM
Originally Posted by Bill208;675030[URL="http://www.Quick-Sling.com"
[/URL] HVAC Hanging system Removed spam ad
:whistling2: Uhhhh, looks kind of hard to get the panels off that furnace....the RNC guys will love it.
