Old 12-03-2008, 12:55 AM   #1
Default Attaching Flex duct to register boot
I am running a 5 inch duct run using flex duct (type F090) to a register boot. My question is, since the flex duct is the same diameter as the register boot, how to a fit the flex over the register boot? Do I crimp the register boot so the flex will fit over it or do I need a coupler?
avshockey is offline   Reply With Quote
Old 12-03-2008, 01:13 AM   #2
hvaclover's Avatar
What is the reason for so small a diameter flex?
Just slow, not stupid.
hvaclover is online now   Reply With Quote
Old 12-03-2008, 01:17 AM   #3
An old Tradesmen
It slides over.
Takes a little practice.
Old 12-03-2008, 03:26 PM   #4
Don't forget to prelube with mastic and use a tie strap over the liner then the insulation jacket.
Daltex is offline   Reply With Quote
Old 12-03-2008, 04:26 PM   #5
hvaclover's Avatar
Hey deltex why mastic?
I freely admit that I use all rigid pipe and very little flex.
I would pull back the outer insulation, push the flex on the fitting, zip tie that, and then push the insulation over the flex duct and fitting and duct tape with approved tape.
What am i missing on mastic?
Old 12-03-2008, 05:17 PM   #6
You should tape the flex (plastic liner) to the boot after putting on the panduit strap. Then you pull the insulation over that and tape the exterior liner to the boot as well.
bluefitness is offline   Reply With Quote
Old 12-03-2008, 05:19 PM   #7
It is uninsulated because it is in a conditioned area. The flex definately does not fit the "torpedo" stile register boot. I called the HVAC place were I purchase it and he said the I would have to crimp the register boot to get it to fit. Would crimping the register boot disrupt the air flow bad enough that this would not be advised. Do they make register boots that have a male end to attach flex to?
Old 12-03-2008, 05:37 PM   #8
hvaclover's Avatar
Heh, I just read the instruction. I don't do enough flex to claim any real expertise in whole system design. But we do kinda specialize in (that is to say each job we've done has been a success) in correcting badly heated home additions.
Old 12-03-2008, 06:54 PM   #9
biggles's Avatar
take a niddle nose pliers and grab the end of the duct about 2" down 1/4 turn the edge all the way around and that will narrow it down to accept the 5" now to attatch it....wrap the end with one full around lenght of duct tape.slip the flex on ,and again the full around duct tape then zip screw it into the duct.if it was insulated you then would pull the insulation over the screws and duct tape that.....the key word here is DUCT TAPE.....2 pieces of duct tape aren't coming apart.
Old 12-03-2008, 07:05 PM   #10
hvaclover's Avatar
SCREWS?
Not criticizing, but wouldn't you worry about the flex ripping? I know you used duct tape but I have seen it come loose over the years and the screws rip loose.
Just asking, like I said flex is not my specialty.
Old 12-03-2008, 07:07 PM   #11
I may be overdoing it but flex is known to get kicked around and pulled on after installation. The weakest link is the connectors at the take offs and jack boots. The mastic glues it solid so you don't have to rely on the zip alone to hold it. I just zip the insulation and now you have me thinking about taping that for more support.
The mastic also really does lubricate it to make slipping it over the fitting easier and it holds it in place while zipping it tight.
Old 12-03-2008, 07:09 PM   #12
hvaclover's Avatar
Well good, then we helped each other out. Mastic it is. Good idea and a very sensible explanation
Old 12-03-2008, 07:10 PM   #13
An old Tradesmen
Technically, all joints are supposed to be sealed with mastic compound or mastic tape.
Old 12-03-2008, 07:17 PM   #14
hvaclover's Avatar
Hey, there's that echo again
Old 12-03-2008, 09:31 PM   #15
Use this to crimp it:
http://www.lowes.com/lowes/lkn?actio...5198-273-HC5VS
More On This Topic
How to Find Total Duct Loss
How to Find Total Duct Loss by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Solutions. On behalf of Expert Village, we are going to do a duct test in this house. Now we are looking for the total loss even the loss to the inside, even the loss where our tape might be leaking or... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The thickness of our insulation is going to make a difference in the R-Value. So if we have... Read More »
Someone has said duct tape is like The Force (from Star Wars) because it has a dark side and a light side and holds everything together. Some people have taken duct tape out of the "holding things together" business and into fashion. People make all... Read More »
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
When preparing for the coming winter months, we often think of our precious flower gardens, pets and our homes, but winterizing your garage can be just as important. Winterizing your garage is simple and easy, can protect valuable equipment and will make... Read More »
flex duck vs metal duck fhammette HVAC 15 11-09-2008 11:17 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 10:28 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 07:26 AM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 04:30 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 03:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
