Attachhing Wall Vent Covers - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2008, 06:32 PM   #1
Attachhing wall vent covers
House was built in 1945. It seems that the walls are some type of 1/2" board that is very hard or at least the plaster coats are.
I replaced a 5x10 supply duct cover. The plaster that the previous screws were attached to has crumbled. I now have no way to attach the cover.
"Normal" drywall compound will not be strong enough to hold the cover.
Any suggestions/tips on what to do?
*MODs: I put this in HVAC since I thought this might be a problem some HVAC people have. Feel free to move it if necessary.
unixb0y is offline   Reply With Quote
Old 10-05-2008, 06:51 PM   #2
If you had some pictures I might be able to offer some suggestions.
Marvin Gardens is offline   Reply With Quote
Old 10-11-2008, 11:41 PM   #3
Here is a picture
The other issue I have is that the wall is not flat around the vent. The wall is kinda wavy.
So the new vent has a gap on one side compared to the other.
Somehow, I should figure out how to build out the wall.
The previous owner user caulking and then painted the vent.
Old 10-12-2008, 12:16 AM   #4
An old Tradesmen
Rewards Points: 6,152
The screw is suppose to go into the sheet metal.
If teeh hole is stripped out too much for the #6 screw to hold, use a #8 screw.
Old 10-12-2008, 12:18 AM   #5
You can take some wood large enough to get through the wall and either glue it or screw it to the back of the wall leaving room for the vent to....well vent. Keep the wood close to the edges of the opening so that your screw for the vent will have something to grab on to.
You will have to use screws long enough to get through the wall and grab most of the wood you put back there.
Unless I am missing something this will work.
My idea of a perfect day: No where to go and all day to get there.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
