Attach Bathroom Fan Vent To Dryer Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 09:43 PM   #1
hohadcr's Avatar
Rewards Points: 306
attach bathroom fan vent to dryer vent
i am adding 2 bath fans and a dryer vent to the 1st floor of a 3plex.
1. can i combine the 3 vents into a main vent?
2. as i cant reach the main vent to the roof, can i guide the vent to one side of the building and get to open air from there?
thank you
hohadcr is offline   Reply With Quote
Old 03-07-2010, 10:01 PM   #2
An old Tradesmen
Rewards Points: 6,516
No, can't combine them.
Why can't you reach the main vent to the roof.
Old 03-07-2010, 10:18 PM   #3
hohadcr's Avatar
Rewards Points: 306
this is an old house; 2nd floor & 3rd floor share the main stack -- 2nd floor using wet venting.
1st floor was formerly modified and dont connect to upper floor and right now has no vent at all.
Old 03-07-2010, 10:35 PM   #4
An old Tradesmen
Ok.
Can't combine them though.
Old 03-08-2010, 08:06 AM   #5
I tend to ask more questions here than I answer, but something doesn't sound quite right.
HOHADCR- Your most recent post sounds like you are talking about plumbing vents, either PVC or cast iron. This sort of venting is totally different from venting exhaust/dryer fans. Maybe I am understanding you wrong, but please don't try to connect an exhaust fan to your plumbing vent stack, that would be dangerous, for sure!
stubits is offline   Reply With Quote
Old 03-08-2010, 08:17 AM   #6
hohadcr's Avatar
Rewards Points: 306
Thanks, stubis.
I do have question about plumbing vents too and posted them in plumbing section.
I got it, no combining plumbing vent with other ventilation.
Question, why cant I combine bathroom vent w/ dryer vent?
Old 03-08-2010, 08:22 AM   #7
I default to "because beenthere says so," but that is too simplistic.
First, I am sure it is a code issue that prohibits it, but even more so, you need to be able to clean out your dryer ductwork and if there are all sorts of wye's and fittings, that is going to be awfully difficult. Also, the dampers included on the bathroom exhausts are weak, so you'll likely end up with lint and moist air from the dryer being blown into your bathroom. By the same token you will end up with smells and moisture from the bathroom making their way to the dryer. Also, with all the moisture from two bathrooms AND a dryer, I think it would just make a total mess of the lint.
I have found that if it sounds like the easy way out, it is probabally wrong.
The Following 2 Users Say Thank You to stubits For This Useful Post:
drtbk4ever (03-08-2010), hohadcr (03-11-2010)
Old 03-08-2010, 04:57 PM   #8
An old Tradesmen
IMC. Section 504.1 Dryer exhaust systems shall be independent of all other systems.
Old 03-08-2010, 05:22 PM   #9
Rewards Points: 502
Don't do it.
The previous owners of my house had this bright idea to do the same thing.
What ended up happening was the exhaust fan became full of lint and a firehazard as now the dry lint was all around the bulb in the fixture.
It also caused moist air and "dust" to re-enter the bathroom....even though there is a one way vent door on the exhaust fan.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 03-08-2010, 06:58 PM   #10
Registered User
Rewards Points: 5,216
Where is Waldo behind door #4: http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
When cleaning your dryer vent.... handy man88 HVAC 0 07-12-2009 10:08 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
Vent dryer through flat membrane roof Vince Rosati General DIY Discussions 6 11-02-2008 03:11 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
