Old 12-29-2012, 07:01 PM   #1
Asbestos wrap ?
I was working in the attic today preparing to replace a exhaust fan for the bathroom when I looked over and saw this duct and what is wrapped around it. Is this asbestos?
rubiks1 is offline   Reply With Quote
Old 12-29-2012, 07:20 PM   #2
Roofmaster
Asbestos wrap ?
Quite possibly, but you need to have it tested to be sure. Can you take more pictures, wider angle and very close up of the edge of the duct where it is opened up? Shoot Macro.
When was your house built?
" A lot of men build things, and a lot of things fall down "
Old 12-29-2012, 07:26 PM   #3
Asbestos wrap ?
In most commercial forms, asbestos looks like a ball of thick fuzz. Asbestos looks fibrous, friable and fluffy, almost like a muddy brown or white cotton wool. Is that what you have as I really can’t tell by a picture?
epson is offline   Reply With Quote
Old 12-29-2012, 08:29 PM   #4
as seen on tv
Asbestos wrap ?
looks like asbestos wrap to me. The stuff on the top is just fiberglass duct wrap ,probably covering the asbestos . You should not disturb it. The stuff in the wall is encapsulated so you should be ok.
qbert is offline   Reply With Quote
Old 12-29-2012, 08:44 PM   #5
Asbestos wrap ?
Here are some more pics. This time taken from my nikon so they should be clearer. I can only see one side of this duct since the way it is boxed in.
Here is a pic of where it is etc and boxed in
Close up
And another
Old 12-29-2012, 08:47 PM   #6
Asbestos wrap ?
how old is the house?
Old 12-29-2012, 09:12 PM   #7
Asbestos wrap ?
Built in 1973
Old 12-29-2012, 09:34 PM   #8
Asbestos wrap ?
Originally Posted by rubiks1 View Post
Built in 1973
Then with all probability it is asbestos as all homes built prior 1975 would have it.
Old 12-29-2012, 09:52 PM   #9
Asbestos wrap ?
I have a HVAC company coming out next Friday to install a dampner on another run. I will ask what the best course of action is. It looks like that paper stops an inch or so up and if that is the case they could cut that entire boot out and replace it. Just guessing here.
Old 12-29-2012, 10:08 PM   #10
Asbestos wrap ?
They should know what to do. But asbestos is not something to fool around with if you’re not sure how to deal with it.
read up: http://web.princeton.edu/sites/ehs/w...sfactsheet.htm
Old 12-30-2012, 12:16 AM   #11
Asbestos wrap ?
1000% agree with you. I suspected that the popcorn in my ceilings contained asbestos so I took a sample to a lab and it came back as 3% chrysotile so in short I dont mess with it.
I did put on a mask with a respirator, some gloves & checked out the pipe being careful not to touch the frayed parts in the picture. The good news is that the rest appears to be in good shape and it goes up 1-2 inches up the pipe so the HVAC company or asbestos removal company could cut it out and then install a new boot etc.
Thanks for all of the info and I will update this thread next Friday when they come in.
Old 12-30-2012, 02:13 AM   #12
Asbestos wrap ?
good luck...
Old 12-30-2012, 12:08 PM   #13
Roofmaster
Asbestos wrap ?
Thank You for the very good pictures.
Yes this duct wrap contains asbestos. The dead giveaway to me is the small corrugation pattern in the sheet. The white fibrous stuff is asbestos, the gray is mostly simple airborne dirt that has collected around it.
If you decide to deal with it, wet it with glycol and water 1-3 parts mixed, and make sure you pressurize your house so dust is forced out of any openings, not into your house and do it on a calm day. A HEPA Mask is obviously needed, and paper throwaway coveralls, with hood and booties.
Double bag and hepa vac after removal. You can buy a hepa filter for most shop vacs.
Use your head, take your time, and think the whole process all the way through to clean up and disposal.
Asbestos Duct Wrap Etrace0921 HVAC 16 05-03-2013 06:23 PM
Is this duct wrap asbestos rubiks1 HVAC 4 10-27-2012 07:23 AM
Asbestos Duct Wrap jvc120er HVAC 16 02-19-2012 06:19 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General Discussion 10 08-17-2010 12:28 AM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 11:49 AM
