Armstrong Package Air Conditioner Furnace Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 06:53 AM   #1
Post
Armstrong package air conditioner furnace issue
I have a Armstrong package unit that is having some furnace issues. The unit appears to be shutting down after about 20-30 minutes of operation. The precombustion blower comes on, and the burners light, but after a short while, the burners go out and the system cycles again. The furnace will run for about 20 minutes then will shutdown and will not restart unless the power is removed\restored to the unit.
I have looked at the control board and it appears to have some discoloration around some of the resistors\capacitors. The blower appears to be working but the airflow is not as strong as it used to be.
The unit is approximately 7-8 years old.
cptkrk is offline   Reply With Quote
Old 12-14-2010, 08:15 AM   #2
Rewards Points: 1,578
have you changed out the air filters? If they are clogged or other obstructions to air flow you could have a shut down. Perhaps flame sensor is dirty?
bob22 is offline   Reply With Quote
Old 12-14-2010, 08:28 AM   #3
Post
The filter has been replaced recently. I even went as far as removing the filter temporarily to see if the airflow improved and it did but not drastically and the furnace still shutdown after about 30 minutes.
Could the issue possibly be that I lost a speed in the blower? I have not cleaned the furnace other than the usual coils.
Tags
armstrong , furnace
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 12:13 AM
Armstrong Ultra 5 Tech 80 furnace rusty427 HVAC 1 12-24-2008 08:33 AM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 08:19 AM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 09:22 PM
Air Conditioner Condensation Issue Unregistered HVAC 1 07-23-2004 02:10 PM
