Armstrong Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 09:33 AM   #1
Have an older style Armstrong gas furnace. Problem is the pilot light comes on and the burner won't ignite. Where should I start looking for problem(s)?
mggt is offline   Reply With Quote
Old 11-02-2011, 12:06 PM   #2
how
Rewards Points: 1,070
Everyone has a different idea of what an older style armstrong furnace is.
Can you give us more info on model/ rough age & style which will narrow down the possibilities.
Standard or mid efficiency?
how is offline   Reply With Quote
Old 11-02-2011, 12:19 PM   #3
REP
Well if an electronic ignition is in place.A thermostat triggers the control box to start the exhaust fan,the fan triggers a pressure switch that tells the control box to start a spark and to open the pilot gas part of the gas valve.Once pilot is established a flame sensor picks up an electronic signal the goes to the control box which triggers the main gas valve to open.
I would say about 7-8 times out of 10 that if the pilot comes on and the main gas valve does not come on it is the flame sensor which is at fault.Since the electronic signal that it senses is such a small voltage,any small coating on the sensor will slow or prevent that very small electronic signal from entering that flame sensor and thus prevent the main gas valve from opening.
REP is offline   Reply With Quote
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Tied-up Inducer Motor Armstrong Furnace CFSpit HVAC 2 02-09-2011 09:00 PM
Armstrong furnace won't fire jgreissi HVAC 10 10-17-2010 06:20 PM
Armstrong furnace Dbenzboy HVAC 2 08-28-2010 02:53 PM
armstrong air ultra v tech 80 furnace model C2E24A-1A Iowachick HVAC 1 11-29-2008 07:15 PM
