Armstrong Furnace Parts - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 12:26 PM   #1
I have an Armstrong Ultra 80 Furnace with a Beckett AFG Series Burner. The oil supply tube is stripped and I cannot find the replacement part. The air tube combo. part number is AF50YB (5 1/2in air tube). I have found a similar part number AF65XN but it it 6 5/8in) air tube. Can I use a longer air tube in this Furnace? Will I need to make any alterations to get it to work properly?
tekwiz56 is offline   Reply With Quote
Old 12-17-2012, 01:44 PM   #2
REP
You can use the longer tube as long as you position the end of it correctly into the combustion chamber.You must also have the correct end cone for the nozzle you are using.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
tekwiz56 (12-17-2012)
Old 12-17-2012, 05:08 PM   #3
Rewards Points: 242
try this.
they should be able to answer any questions
http://www.beckettcorp.com/index.asp
hvac instructor is offline   Reply With Quote
Old 12-17-2012, 07:07 PM   #4
It is exactly the same as the original but it is 1 .125 inch longer.
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Armstrong package air conditioner furnace issue cptkrk HVAC 2 12-14-2010 08:28 AM
Rheem Furnace needs parts or replacement? Bob10 HVAC 2 01-15-2010 06:10 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
armstrong air ultra v tech 80 furnace model C2E24A-1A Iowachick HVAC 1 11-29-2008 06:15 PM
