-   -   Armstrong Furnace Parts (http://www.diychatroom.com/f17/armstrong-furnace-parts-166701/)
tekwiz56 12-17-2012 01:26 PM
I have an Armstrong Ultra 80 Furnace with a Beckett AFG Series Burner. The oil supply tube is stripped and I cannot find the replacement part. The air tube combo. part number is AF50YB (5 1/2in air tube). I have found a similar part number AF65XN but it it 6 5/8in) air tube. Can I use a longer air tube in this Furnace? Will I need to make any alterations to get it to work properly?
REP 12-17-2012 02:44 PM
You can use the longer tube as long as you position the end of it correctly into the combustion chamber.You must also have the correct end cone for the nozzle you are using.
hvac instructor 12-17-2012 06:08 PM
try this.
they should be able to answer any questions
http://www.beckettcorp.com/index.asp
tekwiz56 12-17-2012 08:07 PM
It is exactly the same as the original but it is 1 .125 inch longer.
