Armstrong Furnace How To Wire Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 08:41 PM   #1
Armstrong furnace how to wire humidifier
I want to hook up a humidifier to my armstrong furnace, I don't know how to wire directly to the 24volt terminals in the furnace, so that when the heat kicks on, so does the humidifier. Can anyone help me out?
http://s1196.photobucket.com/albums/aa414/doublewide6/
doublewide6 is offline   Reply With Quote
Old 12-15-2010, 06:45 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
what humidifier do you have brand and model number? can you take a picture of the control board?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-15-2010, 08:40 PM   #3
Wire it to the G terminal so it comes on with the blower. http://geothermal-pa.com
geothermalpa is offline   Reply With Quote
Old 12-16-2010, 06:20 AM   #4
My furnace is an Armstrong
Model EFC20LAA-1A
Serial No. 6005H19337
Voltage 240/208
Honeywell HE225DG115 TRUE IAQ By-pass Humidifier
The pics of the wiring schematic is on my first post in this thread. Thanks for all your help. DW
Old 12-16-2010, 08:23 PM   #5
AKA HVACTECHFW
http://www.alpinehomeair.com/related...de%2001.10.pdf
see page 11
IT IS WHAT IT IS
Old 12-16-2010, 08:50 PM   #6
Thanks for the manual. I looked inside the furnace, but can't determine where the 24v connection would be. Do you know if this humidifier will turn on and off when the furnace turns on and off, if I have it plugged in to a 120 wall outlet separate from the furnace? Thanks
Old 12-16-2010, 09:30 PM   #7
AKA HVACTECHFW
it would be on the control board located in the blower compartment. the model number of hum that you gave me was for a bypass unit. It should not need 120v other than for the transformer.
IT IS WHAT IT IS
Old 12-17-2010, 06:20 AM   #8
I am figuring if I can't hook it directly to the furnace board I will use an outlet to plug it in. Is there anywhere I can get a picture or schematic of the location of the 24V transformer? Thanks again for helping.
Old 12-17-2010, 07:24 AM   #9
AKA HVACTECHFW
there should be two terminals on the board one labeled HUM H and one labeled EAC H ....if you have hum on board then use that for the hot leg of the high voltage side of the transformer and take your other leg (common to a neutral post on the control board. If you don't have HUM then you can use EAC
IT IS WHAT IT IS
Old 12-17-2010, 09:43 AM   #10
hvactech,
I really appreciate your effort and help in this matter. I'm pretty good with home wiring and repairs, so I think I can handle this. I am going to go home and try to locate the terminals you are speaking of. I might post a picture or a video for you to check out if I can't find the exact terminals you are speaking of. Once again I will keep you posted and I appreciate you taking the time to help me. Thanks DW
Old 12-17-2010, 05:16 PM   #11
HVACtech,
This is a video I was not able to find any HUM H or EAC H Neither are on the wiring diagram. Please take the time to see the video and let me know what you think. Thanks again for your needed help. DW
Old 12-17-2010, 05:31 PM   #12
AKA HVACTECHFW
do you have a heat pump? If you do then please tell me what terminal designations are in your t-stat.
IT IS WHAT IT IS
Old 12-17-2010, 07:23 PM   #13
Thermostat Indoor Unit Outdoor Unit
Red Red Red
Yellow wire nutted Yellow
Orange wire nutted Orange
White Black + White +Brown White *************edited**************
Green Green ------
Blue Blue Blue
These are the wire nuts on the outside of the furnace that connect the thermostat to the furnace + the heat pump.
I do have a heat pump. Here is how it is wired up. The Thermostat and outdoor unit have 20 gauge wire and the indoor furnace has 14 gauge tied together with wire nuts.
The following is what I found behind the Thermostat:
W2 White
G Green
B ------
O Orange
Y Yellow
R Red
C Blue
E Black
Old 12-17-2010, 07:32 PM   #14
AKA HVACTECHFW
Do you have any extra wires going to thermostat from air handler? If you do hook it to B...
IT IS WHAT IT IS
Old 12-17-2010, 07:57 PM   #15
Thanks for the quick response.
All wires going from the thermostat terminals do wire nut to the indoor unit. However there is one extra wire not in use. It is a brown 20 gauge wire it runs from the thermostat to the furnace, but not connected on either end.
********* I edited posting #13 please see the wiring correction****************
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Armstrong Furnace Burner Cutout tcar HVAC 3 11-20-2010 11:26 PM
Add humidifier to outdoor furnace. prokop HVAC 3 11-30-2009 07:54 PM
Humidifier and dehumidifier on furnace loadie HVAC 2 12-07-2008 04:16 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
