Armstrong Furnace Burner Cutout - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 07:18 PM   #1
Armstrong Furnace Ultra 80 Burner Cutout
It's cold in shy town and the furnace keeps cutting out, and on top of it, it needs to be re-set to start - ouch!!!
Furnace ignites well, all five burners turn on, runs for 30 seconds to a few minutes then, it shuts down, and the process starts over
Tried to jumper the pressure switch, same problem, maybe it last longer
Now it when it shuts down, I have to push the re-set button for it to re-start
Could it be a dirty sensor?, why would this require the unit to be re-set
I had to push re-set when I starved the furnace, by closing the doors to the small room the furnace sits in, worked fine after I re-set and kept doors open
Any ideas would be welcome...
Tcar
tcar is offline   Reply With Quote
Old 11-20-2010, 08:08 PM   #2
30 year tech
hvac122's Avatar
What reset button are you pushing? Sounds like a flame rollout limit. This could be a dangerous situtation. Post pics of what you are resetting.
hvac122 is offline   Reply With Quote
Old 11-20-2010, 10:17 PM   #3
Old 11-20-2010, 10:26 PM   #4
HVAC / Plumbing
Tcar
How small is the room ?? Maybe starving the furnace for combustion air
kenmac is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
furnace burner problem brent h HVAC 2 01-11-2010 07:50 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
