Armstrong Electric Heat Pump Fan Won't Turn Off - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 11:05 AM   #1
Armstrong electric heat pump fan won't turn off
Hi folks, I know very little about HVAC but am a pretty good troubleshooter/parts changer and can figure most things out with a little help.
I'm also usually pretty good at searching forums for help but I can't seem to find any using the search here.
I have a split system heat pump with the AC compressor outside and the A Frame inside the house in the closet.
The other day after using the heat(for only about the 2nd time this year) my fan won't turn off. I can switch to AC or Heat or Off and it won't go off. The fan on the Tstat is set to auto.
I can disconnect the Tstat and it will still stay on.
the only way to get it to turn off is to flip the breaker.
Last summer I had a similar problem and it was the fan relay. I took mine apart and one of the contacts was slightly discolored but nothing much. I sanded the contacts and put it back in same problem. I then replaced the relay with a new one and still have the same issue.
I do notice that it seems like the fan isn't "wide open" running, maybe 1/2 or 3/4 speed. When the AC kicks on you can hear the fan catch another gear and turn more full speed.
I saw one comment while searching it could be some kind of heater safety thing that is stuck or something but I don't know where to look.
When I look inside the Aframe section with the cover removed I can see my fan relay and two other larger relay type items and then another type module that I'm not sure of. I keep reading about a circuit board but I don't see one anywhere.
I know this might be a totally newb question but I am usually pretty good at figuring these things out and can't really afford to call my HVAC guy until next month and I don't really want that fan to run continuously for a month.
I just remembered there might be a piece under the house, the air handler etc, should I be looking there?
cbordea is offline   Reply With Quote
Old 10-21-2011, 11:09 AM   #2
one other comment, when the fan is running it appears to be room temp air.
It does not appear to be warm or cool.
The heat/AC seem to work fine. If I have the heat on set at 71, when the house gets cool the heat kicks on and warms up.
When I have the AC on set at 73 when the temp gets over 73 the AC kicks on.
Everything appears to work fine except the fan won't shut off.
I really don't know but I almost feel like the fan thinks the heat is on and that it needs to move air to keep stuff from overheating but I don't really know.
Old 10-21-2011, 12:23 PM   #3
Your fan sequencer (relay) is stuck closed, or the thermostat wires are shorting to each other.
Master of Cold is offline   Reply With Quote
Old 10-21-2011, 12:32 PM   #4
if by sequencer/relay you mean this, I have replaced it with a new one and the old one looks fine inside.
on the Tstat, I have a hunter digital, I can remove the tstat from the housing which disconnects the Tstat from the wires and it still runs.
Old 10-21-2011, 12:34 PM   #5
Take the green wire off of the relay and see if it runs.
The Following User Says Thank You to Master of Cold For This Useful Post:
cbordea (10-21-2011)
Old 10-21-2011, 01:09 PM   #6
I went to pull off the green wire and the blower was already off.
I hadn't checked it today, maybe not even yesterday.
A little more history.
about 2-3 week ago we knew some cool weather was coming so I turned the heat on in the middle of the day to burn off that stuff that usually kicks off the fire alarm the first time the heat comes on. I didn't have any issues.
A couple nights later we knew it was going to be cool so we set the heat to come on at about 70.
We had a couple of cool nights so we left the heat set that way for a couple nights.
it then warmed back up. When I switched over to air, I noticed that the blower wouldn't shut off.
It stayed on for about a week while I have been troubleshooting/reading/talking to folks.
We've had a couple cool nights and have had the heat on for a couple nights, no air or heat during the day.
Do you think it is Tstat/wire related or something on the heat side that finally ran long enough to correct itself?
Old 10-25-2011, 04:26 PM   #7
I've had the heat on a few days now and I noticed the blower is stuck running again.
I'm going to crawl under the house and see if I can notice anything there.
Any ideas?
Old 10-25-2011, 06:28 PM   #8
ok, I removed the green wire from the fan relay that comes from the Tstat, the blower still stayed on.
I went to the AC compressor and pulled the cover off of the circuit board. The only thing I can see that looks odd is there is a red and green light and both are flashing. The thermostat is in the off position with the fan on auto. The breaker was still on.
there is also a breaker outside to the AC compressor, a big box with a module you remove and flip over with on/off on it. I pulled that out and the fan is still running.
I know sometimes with auto issues pics help, these are low quality pics so they load fast.
here is a pic of my A frame unit,
here is a pic of stuff inside the A frame unit
here is another view with the fan relay
here is a pic of the circuit board outside.
any help is sure appreciated!
Old 10-27-2011, 01:10 PM   #9
I've read on another board about tapping a module on the circuit board.
From my pic above does anyone have an idea which one?
I don't want to cause any more problems than I already have.
Old 10-28-2011, 08:42 AM   #10
ran the air some yesterday and then the heat last night, the blower is still on.
Old 10-31-2011, 08:46 AM   #11
it has been cool lately, ran mostly heat. The blower is off now. This doesn't make any sense.
Electric Forced Air Furnace - Replacing AC unit w/ heat pump? burnt03 HVAC 2 09-18-2011 11:00 AM
Help deterimine age of Armstrong packaged heat pump, model # PWC18E7 Ser # A20626DMA Mark Gammell HVAC 2 04-16-2011 11:20 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
electric heat pump issue gator5220 HVAC 4 11-29-2010 10:40 AM
Cost-Benefit for electric vs heat pump, do my calculations look sound? chazman113 HVAC 13 08-13-2010 04:37 PM
