Old 02-20-2011, 01:14 PM   #1
Armstrong Air Ultra V Tech 80
I am getting 6-1 flashes telling me that I am getting locked out due to ignition failure.
Any assistance out there?
rrjjrr is offline   Reply With Quote
Old 02-20-2011, 01:17 PM   #2
Professional
have you run it through a heating sequence while watching to see what is or is not happening? Going to need more information fromm you than just the code. Could be many different things for that code. Does the ignitor glow? Do the burners come on and then go out after a few seconds?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-20-2011, 01:44 PM   #3
I cut the power to the furnace at the box. Turned the t-stat to 73. The indicator light is showing bright-dim as it should, all systems are firing at the moment. T-stat hit 74 and system shut down, blower still blowing and indicator light still bright-dim.
Old 02-20-2011, 01:47 PM   #4
Professional
when you turned the power off, you reset the system. it may not act up for a while now....blower still blowing due to heat off delay built into blower controller.
IT IS WHAT IT IS
Old 02-20-2011, 02:18 PM   #5
T-stat is at 68. Nothing kicking on, getting the same 6-1- flash.
Old 02-20-2011, 02:20 PM   #6
Professional
need more information............. run it through a cycle, if it runs ok then run it through another one until it acts up.........
IT IS WHAT IT IS
Old 12-10-2012, 08:28 PM   #7
Angry
I have this problem and the igniter glows then the flame comes on for a second igniter goes out and it shuts off. It cycles thru this 3 or 4 times then totally shuts down. Getting the same 6 + 1 codes after that. Until then regular heartbeat. Any ideas? At this point I could use any advice wife and kids are starting to think I am a dumba$$!
POS - DIY is offline   Reply With Quote
Old 12-10-2012, 08:45 PM   #8
Professional
Clean the flame sensor
IT IS WHAT IT IS
Old 12-10-2012, 08:53 PM   #9
seems to me the pressure switch is not reseting after a cycle.....pull hose of inducer clean small port with paper clip and gently open and close pressure switch by sucking and blowing on hose...run it thru a cycle..ben sr
Armstrong Air Heat&Air Unit Ultra 5 tech 80 Rubberfoot Electrical 1 06-12-2010 10:12 PM
Igniting Armstrong Ultra V 80 Spartacus HVAC 2 07-27-2009 09:33 PM
Armstrong Air v tech 80 furnace jkunzman1 HVAC 1 01-08-2009 10:39 PM
Armstrong Ultra 5 Tech 80 furnace rusty427 HVAC 1 12-24-2008 09:33 AM
armstrong air ultra v tech 80 furnace model C2E24A-1A Iowachick HVAC 1 11-29-2008 07:15 PM
