Armstrong Air - Circulation Blower Not Start - HVAC - DIY Chatroom Home Improvement Forum
Old 03-13-2006, 08:58 AM   #1
Need a second opinion...hope to not freeze in Minnesota
I have an Armstrong Air Ultra V furnace. Recently the circulation blower does not come on.
I shut down the furnace and turned it back on to check the sequence of operation. The inducer motor comes on fine. Then the call for gas and the burners kick on without problem. Then the call for the circulation fan, but it does not come on and I get a red LED light showing on the interface board.
With the furnace powered down I have checked the filter, the connections, and that the fan spins without problems.
My thinking is the it may be a bad interface board, but wanted to get some thoughts...:confused:
Chris-MN is offline   Reply With Quote
Old 03-18-2006, 02:00 PM   #2
sub-contractor
Check the power to the motor when calling for fan.
if there is power to the motor replace capacitor and motor.
if there is no power, or incorrect power, check line voltage to unit. if correct, replace board.
If you are unfamiliar with electrical schematics or troubleshooting, CALL A SERVICE TECH. as this can be hazardous to your health.
Aceinstaller is offline   Reply With Quote
Old 03-30-2006, 12:19 PM   #3
Thanks Aceinstaller. You were right on!
There was power to the motor, but it wasn't kicking on. So, I replaced the powerhead unit to the GE motor and this fixed the problem. This furnace had a GE motor and I was able to just replace the power head unit. This was good since replacing the whole motor would have been expensive
Thanks Again!!
Old 06-23-2008, 04:04 PM   #4
Chris,
I have same furnance and my motor head also just went...Had a very hard time finding the part....I got it from a distributor who had to order it from Allied Air (Armstrong parent co.) They charged me $425 for the unit which seems outrageous. Do you remember what you paid?
DONRILEY is offline   Reply With Quote
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 10:01 PM
Goodman HVAC gmp100-3 Inside blower problems ray_adrea HVAC 4 06-28-2007 12:31 PM
Induction blower seal ktritz HVAC 4 03-05-2007 08:52 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
