Armstrong - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 03:59 PM   #1
armstrong
I have a armstrong SX 90 ultra furnace model guk075d10. THE INDUCER MOTOR KICKS IN THEN THE PILOT LITE COMES ON AND THATS IT .If you reset the circuit breaker (turn it off then back on) the furnace will go through a complete heating cycle . this will last for a day or two then the inducer motor and pilot lite will work until you reset the breaker
pete 3900 is offline   Reply With Quote
Old 01-22-2011, 04:15 PM   #2
BIGRED
Rewards Points: 252
Turning off the breaker resets the control board in your furnace. Do you get a blinking light or lights associated with that board? You should be getting a failure code in a blinking light that should steer you in the right direction, but also if you are at least getting a pilot light without lighting the main burners try cleaning the flame sensing wire or rod that lays in the pilot flame and loosen and tighten the sheet metal screws that fasten the board and the pilot flame assembly and any wires to the furnace sheetmetal. Something is dirty and can usually be cleaned up without calling the repairman.
Grampa Bud is offline   Reply With Quote
Old 01-22-2011, 04:22 PM   #3
there is no error code lite on this unit looked all over for it on the circuit board
Old 01-22-2011, 04:34 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
start out cleaning the flame sensor that looks like this . If that doesn't work then you need to measure voltage between m/p and m on gas valve while the pilot is lit.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Can I glue down an Armstrong locking hardwood floor? Fixitgeorge Flooring 10 01-30-2013 11:49 AM
Armstrong furnace Dbenzboy HVAC 2 08-28-2010 01:53 PM
armstrong engineered wood floring kbpelham Flooring 0 06-04-2010 01:30 PM
Armstrong unit vs York unit Nayr HVAC 5 02-04-2010 12:54 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
