Closed Thread
Old 12-05-2009, 03:11 PM   #1
Arlington, VA - Is this a BAD estimate for Radiator/Boiler System Repairs?
OK, have a leaking radiator valve, and a leaking pipe that feeds the radiator valve, and I had a local company come out and give an estimate for 920.00 dollars.
Am I getting ripped off?
Here is the description from the estimate:
"Need to drain down the boiler. Replace both parts need to then refill, purge air and inspect for leaks."
Radiator Valve: 275.00
Boiler Drain: 145.00
Drain Refill and Purge: 500.00
I'll post pictures in a few...thoughts?
sonny1975 is offline
Old 12-05-2009, 03:47 PM   #2
Xtreme DIY'r
This site is geared towards DIY, not cost estimates
Get several local quotes on the repair & check references
Prices vary widely by area & in many cases by a visual inspectiob
Thank you
Scuba_Dave is offline
Closed Thread
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 06:24 AM
new system install.....questions firedogut HVAC 4 10-04-2009 08:10 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
