Area Around Baseboards Wet - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 06:18 PM   #16
An old Tradesmen
Rewards Points: 6,462
Originally Posted by danpik View Post
Something still does not make sense. If the heating run was on due to the circulator running/zone valve open due to the thermostat "on" then it stands to reason there should be heat in that run as well. Hot water pipes don't condensate and there would be heat in the run making the house warmer. Just thinking out loud...so to speak
Some systems are set up that the circ runs 24/7. the stat can only turn the burner on. And then only if the outdoor reset allows the burner to run.
What to install first: 8x8 post OR paver area cgilbert Landscaping & Lawn Care 1 03-18-2011 07:21 PM
Insulating area under roof... BlueBSH Building & Construction 10 11-08-2010 01:43 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-31-2008 12:03 AM
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 04:10 PM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
