ARD Vs MARD Dampers - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 05:20 PM   #1
Rewards Points: 640
ARD vs MARD dampers
what is the different between Automatic round dampers and modulated automatic round dampers? I know the MARD's have 3 wires, I assume this means they have to power open and power close? as opposed to ARD which has a spring open or spring close?
What would you use when zoning? Benefits to either of them?
BlueBSH is offline   Reply With Quote
Old 02-27-2011, 06:42 PM   #2
An old Tradesmen
Rewards Points: 8,202
A modulating zoning panel, or a static pressure sensor to modulate it.
Old 02-27-2011, 07:04 PM   #3
Experienced
Jackofall1's Avatar
If I were setting up a zoned system, I would be looking at basic open/close automated dampers, this being, a modulating damper would cause too many pressure variables in the system, resulting in a very complex control system to "modulate" to maintain downstream pressure.
The pressure sensors for such a system are expensive and require regular calibration to work properly.
Mark
Old 02-28-2011, 12:22 AM   #4
"HVAC Pro"
seatonheating's Avatar
Why are you asking?
seatonheating is offline   Reply With Quote
Old 03-01-2011, 09:57 AM   #5
Rewards Points: 640
Originally Posted by seatonheating View Post
Why are you asking?
at the moment its just for my own education as I decide what to do in the future with my system
Old 03-02-2011, 07:00 PM   #6
Rewards Points: 77
One big difference , about 3x the cost...on the MARDs
AirstarFilters is offline   Reply With Quote
Old 03-02-2011, 07:36 PM   #7
hillbilly guru
Send a message via Yahoo to hvacguytn615
the cost is not that great of difference the 2 wire will open if the damper moter fails most of the time the 3 wire will depend on if the damper is in the open or closed postion carrier zoneing systems would be the most common to have the 3 wire in residential apps but in most cases it will be up to you both types of dampers will control air flow
hvacguytn615 is offline   Reply With Quote
range hood, two dampers in cold climate? zantar Appliances 12 04-13-2011 08:19 PM
Do i need dampers? nickm1024cobra HVAC 3 02-17-2011 04:41 AM
geothermal units/ dampers and zones standard? MLMIB HVAC 5 10-24-2010 02:12 PM
AC backdraft dampers? wmmurphy HVAC 6 10-23-2010 05:10 PM
Manual dampers vs. motorized w/smart sensors and zone control... charljlee HVAC 0 06-27-2010 12:05 PM
