Arcoaire Furnace Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 10:15 AM   #1
Rewards Points: 264
Arcoaire furnace won't light
ok it's down to 53 degrees in the houe. We turned the furnace on last night...NO HEAT
checked the furnace. Looking through the sight glass I can see a glow then it dims out- the burners do not ignite.
I called service guy, and there are appearantly many of us who wait til the last moment to fire up the furnace. He can't come until next week. Would like to see if I can get it going on my own....
There is gas, lp, That was the 1st thing I checked. all other LP appliances are working fine
Any Suggestions?
What have I done is offline   Reply With Quote
Old 10-29-2010, 10:46 AM   #2
HVAC / Plumbing
Use vm. check to see where you lost 24v, limits, ps
kenmac is offline   Reply With Quote
Old 10-29-2010, 10:50 AM   #3
Rewards Points: 264
can you dumb it up for me a bit. I have no idea where to be checking for 24v at this point...
babysteps! I got the cover off noticed the glow and no fire..that's where I am now
Old 10-29-2010, 11:00 AM   #4
HVAC / Plumbing
You will have to know the location of all the limits & ps to be able to check with volt meter. You may have several limit switches on your unit. If your unit has a vent motor you will have a ps. The ps will have a small rubber hose to vent motor
Old 10-29-2010, 12:23 PM   #5
Rewards Points: 264
it does have the vent motor with a small diameter rubber tube. I disconnected the tube and the glow goes off. reconnect and the glow comes back on. so pressure switch seems to be working...right?
i will have to google to find where the limits etc are
Old 10-29-2010, 06:07 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,098
Post the make and model # and pics of it with both front doors off so we know what you have.
Old 11-02-2010, 06:48 PM   #7
Rewards Points: 264
turned out it was the pilot ignitor honeywell q3450c. ended up costing $185 with a service call. not too bad and i have heat
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Weathermaker 8000 gas furnace will not light karyn HVAC 1 01-24-2010 12:17 PM
Carrier Furnace Series 160 Pilot Light issue eastons HVAC 2 03-15-2009 03:26 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace won't light BHAYDEN69 HVAC 2 11-12-2008 07:21 AM
