Arcoaire EnviroPlus 90 And Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2009, 10:29 PM   #1
Arcoaire EnviroPlus 90 and Humidifier
I'm looking to add a humidifier to our furnace. I have located the Hum terminal and next to it is a N terminal which appears to be neutral.
Does anyone know if that terminal is 24v or 110v? To test the terminal properly, would I connect the multimeter to the HUM and the N terminals and then check the voltage?
StigMX5 is offline   Reply With Quote
Old 12-26-2009, 09:31 AM   #2
Test it as you wrote. The hum terminal will only be powered with the furnace heating .
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 08:42 PM
Newbie needs help in wiring humidifier. gm2685 HVAC 3 11-14-2009 12:40 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 10:12 AM
Wiring a Humidifier tallcoopscoach Electrical 5 12-02-2008 02:00 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
