Old 11-19-2008, 08:48 PM   #1
Question
Aquastat transformer blowing
I have an old boiler and one day it would not start. I checked w/ volt meter and found tranformer was dead. I replaced it and it blew imediately. I can start the boiler manually by jumping the relay. Any idea what the problem is. Is it the gas valve?
scottsbws is offline   Reply With Quote
Old 11-19-2008, 09:02 PM   #2
doubtful its the gas valve if its low voltage and working by jumping the relay how are you jumping relay just pushing contacts in? can you take pics?
kennzz05 is offline   Reply With Quote
Old 11-19-2008, 09:07 PM   #3
The aquastat has a relay in it that I activate by wedging a plastic paint scraper in (don't laugh). This activates the circulator. Then there is a switch on the gas valve that says auto or manual. I switch it to manual and the boiler fires up. If pictures help I will be more then happy to post. But unfortunately I'm not home at the moment.
Old 11-19-2008, 09:13 PM   #4
the gas valve must be ancient if you can open it without electricity as a guess id say something within the aquastat is shorted but pics would prolly help
Old 11-19-2008, 09:21 PM   #5
Yes..I heard it was ancient. But when I first found the transformer to be dead I replaced the entire aquastat. As soon as I turned up the thermostat to test it, it blew again.
Old 11-19-2008, 09:43 PM   #6
try reading for continuity between the terminals and the metal case of the valve one terminal at a time with wires off read them the same way(wires to ground). but really if the valves that old its more than likely the prob are you sure the aquastat turns the valve on and not just run the pump id think something that old would use a pilot generator(thermopile)
Old 11-19-2008, 10:37 PM   #7
Yoyizit's Avatar
It takes quite a bit of power to immediately blow a xformer. Coils are usually hardy.
Input voltage way above 120v?
Less likely is a downstream short.
What volts, amps for this xformer?
Can you post a schematic?
Old 11-19-2008, 10:46 PM   #8
yoy: its the little one i belive that is part of the aquastat as he said he replaced the aquastat there pretty small less than 40va i think
Old 11-19-2008, 10:57 PM   #9
Yoyizit's Avatar
So it's certain that it's blown? This one puts out 24vac? Thx.
Old 11-19-2008, 11:00 PM   #10
More On This Topic
How to Test Fog Light Wires
How to Test Fog Light Wires by Expert Village
Hi, my name is Nate McCullough on behalf of Expert Village. In these clips we're going to talk about the proper way to diagnose and replace your vehicle's fog lights or accessory lights. In this clip I'm going to talk about the proper way to diagnose the... Read More »
How to Install a Fan Relay
How to Install a Fan Relay by Expert Village
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Now we're going to tame an octupus. We need to put in a fan relay. And we're just going to choose a... Read More »
Hello, my name is Acton Seibel and on behalf of Expert Village.com we are going to talk about how to clean the underside of your lawn mower deck. You are going to need a couple of things. One is a scraper. I am using a regular old paint scraper but any... Read More »
A shocking book is definitely designed for adults. The racy picture on the front will entice those around it to open the book to see more. As soon as the book is opened, the curious reader is jolted from the shock of a 9-volt battery. Here's how you can... Read More »
EMF stands for "Electromagnetic Field," and some believe that EMF readings are useful in identifying the presence of ghosts. Low level and moving electromagnetic fields are said to occur at locations that are experiencing paranormal activity. Evidence of... Read More »
Westinghouse Outdoor Transformer Question dandy Electrical 3 11-01-2008 02:53 PM
Central Ac transformer question Rschrei518 HVAC 4 10-20-2008 09:21 PM
A/C not blowing cold air... rnorred13 HVAC 4 05-18-2008 08:44 AM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
Need Help with odd transformer jSPENCE Electrical 2 11-05-2006 07:59 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
