Aquastat/Thermostat DHW Question. - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 03:51 PM   #1
Aquastat/Thermostat DHW question.
My mom moved into a new house last year which had a different DHW setup than she was used to. Before, she had an oil fired boiler for heating and a separate electric water heater. The new house has an oil fired boiler with an integrated DHW coil. She complained that the water was too hot and that she didnt like the boiler running all year long(even ran out of oil because she didnt think of it in the summer) and was considering installing an electric water heater. I figured that was not the smartest or most economical plan, and that easier things could be done, like using anti-scald valves, a mixing valve at the boiler, or just getting used to adjusting the water temp at the fixture more carefully(I never had a problem with DHW coils in the places I lived), but she and my brother-in-law went ahead and installed one anyway. She said she was happy with it and that now she could shut the boiler off during the summer months and save fuel.
My question is first, what the best option would have been for that complaint from an outside perspective and if killing the boiler for several months is a bad practice.
My other question was if it would be a recommeded practice to wire the aquastat and thermostat in series to eliminate having to manually turn the boiler off when there will be no calls for heating. It's just one zone, so wiring the devices in series will only turn the boiler on when there's a call for heating and it will cycle on and off then based on the aquastat. Is this a bad idea?
Nital101 is offline   Reply With Quote
Old 03-04-2012, 04:50 PM   #2
An old Tradesmen
Rewards Points: 6,498
Electric water heater was the best option.
Aquastat can be wired to bypass the low limit function.
Old 03-04-2012, 06:55 PM   #3
By that you mean...exactly what I described? or something different?
Old 03-04-2012, 07:44 PM   #4
An old Tradesmen
Only a wire change in the aquastat, nothing with the thermostat wiring.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
