Aquastat Temp Setting - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 07:15 AM   #1
I just purchased a home with a dunkirk boiler system. I noticed the other day it smelled hot so i walked down and looked at the gauge on the boiler. It was reading 20psi and 212 degrees. I let it cool down and again turned the thermostat up to see what temp it shut off the burners at. Again it went to 212 degrees before shutting off the burners. Is this normal? Is 212 to high?
ztekdesign is offline   Reply With Quote
Old 12-22-2011, 08:24 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
no more than 200. 180 if it is baseboard fin tube. 190 if radiators.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-22-2011, 08:45 AM   #3
OK, thanks. It is a baseboard "fin" type system. Most of the info I have found said 180 is normal for most hydronic systems. I have the manual for the boiler and it just said between 140 and 240 it can be set depending on ambient air temp. Now I have to just figure out how to adjust the dial. It's a Honeywell L8148a aqua-stat and it has a serrated dial with a stop arm on it. The lowest setting on the Aquastat is 180 and the highest is 240. I think I will just set it down to 180-190.
Old 12-22-2011, 08:46 AM   #4
AKA HVACTECHFW
just turn the dial
IT IS WHAT IT IS
boiler temp overshoot johnnyzero HVAC 0 11-08-2011 09:52 AM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Burner always stops at LOW setting on L8124L pleasehelpmike HVAC 2 01-19-2011 08:22 AM
Temp switch / aquastat? Joe F HVAC 3 10-29-2009 11:38 AM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
