Aquastat Relay - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 12:02 PM   #1
aquastat relay
the sensor wire broke to my relay, is there a way to jumo the aquastat to run the burner for a few hours to heat up the house?
aquastst is offline   Reply With Quote
Old 10-23-2011, 12:24 PM   #2
biggles's Avatar
sure if it is only 2 terminals flip one wire to the other terminal use the screw to lock it down or add a spare light switch if you can run wires into the wires on the aquastat for now...check the water temp and pressure as you heat...140F-160F cycle it off.. local grainger might have the control if your changing it got a control number on that stat
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
Bad relay in Honeywell aquastat operagost HVAC 0 08-18-2011 12:20 PM
Buzzing from Aquastat relay... jritkes HVAC 1 04-23-2009 08:18 AM
Aquastat Relay replacement Carloscda40 HVAC 9 03-21-2009 04:42 AM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
