Aprilaire Humidifier Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 02:56 PM   #1
I have an Aprilaire 600 Humidifier that was already installed when I purchased my home but has never been operational since I have been here. I am now trying to get it going and it isn't working.
I have checked the wiring and it seems to be correct. I have also checked to make sure there is no clog in the water supply. Finally I have verified that there is 24v going into the humidistat but that power never gets to the solenoid valve no matter where the dial is on the humidistat and no matter what part of the heat cycle the furnace is on.
I know it worked for the previous owner because the water panel is full of mineral deposits.
DO you think the humidistat itself went bad?
MilkyTech is offline   Reply With Quote
Old 01-14-2013, 06:45 PM   #2
chitownken's Avatar
Rewards Points: 510
Easy way to tell is to connect the two wires at the hunmidistat together. If the solenoid valve opens, bad humidistat.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
ben's plumbing (01-14-2013)
Old 01-15-2013, 12:38 PM   #3
thank you. valve works so I guess I need to replace humidistat. only problem is that the new aprilaire humidistats have a more complex wiring scheme than this old manual humidistat I have
Old 01-15-2013, 04:04 PM   #4
Rewards Points: 484
You dont have to buy an aprilaire humidistat and if you search online, you'll find many different types of manually operated humdistats with a simple two wire connection.
Aprilaire even sells the manual one that you need.
sammy37 is offline   Reply With Quote
Old 01-16-2013, 07:10 PM   #5
I disconnected the humidistat and hooked up a simple 15a wall switch for the solenoid valve.
I have it wired so that with the wall switch on, the valve is open while the furnace is ignited rather than when the blower is on.
I am using the saddle valve to throttle the water flow and control the humidity level. Its been around 10% RH inside the house all winter without the humidifier working. Now I've got it pretty steady around 25%
Thanks for the help!
Old 01-16-2013, 10:24 PM   #6
Rewards Points: 484
I guess your planning on ordering another humidistat? As far as regulating water with the saddle valve, you'll do more harm than good to the pad inside, as having dry spots and not keeping the pad saturated will cause it to build up mineral deposits much faster.
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 05:26 PM
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 10:10 AM
Need advice on Aprilaire Humidifier, 2 questions. Maack HVAC 0 12-30-2010 06:49 PM
Aprilaire 400A Humidifier Installation Winchester HVAC 4 12-13-2008 11:57 AM
Carrier MPV Furnace & Aprilaire humidifier mikeramos HVAC 4 11-21-2008 06:04 PM
