Old 12-17-2009, 07:17 PM   #1
Aprilaire Humidifer Maintenance How To ?
I have an Aprilaire humidifier model 550 in my home that was with the house when it was built. Other than changing the filter pad once and the water drip hose once, no other maintenance has ever been done on the unit. I'm sure that over 15 yrs(the age of the home and humidifier) that things should be replaced on it to make the unit run at peak performance?
Are there things that should be changed out for sure just from your experience no matter what, other than the filter? Thanks for the advice.
kennykenny is offline   Reply With Quote
Old 12-17-2009, 07:24 PM   #2
An old Tradesmen
Make sure that the drip tray still has its grit. That helps the water flow evenly across it.
And change the pad yearly.
Aprilaire part 4851 Blower Activation Relay glassr HVAC 0 09-25-2009 04:57 PM
Oil Boiler Maintenance Piedmont HVAC 4 04-22-2009 04:17 PM
hot water heater annual maintenance: a word to the wise diy888 Plumbing 16 03-19-2009 10:59 AM
Property Preservation, Maintenance & Repai tallenbaugh Off Topic 1 12-13-2008 08:23 AM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 08:49 PM
