Aprilaire 760 Testing / Repair - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 10:01 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Aprilaire 760 testing / Repair
My Aprilaire that used to work does nothing. I pulled it apart, the hoses, solinoid, spray head, etc are all clean. H20 has a good strong flow going into solinoid.
I've jumped the wires, and it does not even attempt to engage. - no noise, nothing. It is pluged into a working power source.
Any ideas as to what else I can do with this thing? or is it time to just order a new one?
Jamie
jamiedolan is offline   Reply With Quote
Old 10-28-2008, 10:14 PM   #2
Check if the xformer primary winding is open-circuited.
Then check the solenoid winding.
You could check that the humidstat closes the contacts at reasonable humidity levels but I doubt this would be the problem.
Old 10-28-2008, 10:20 PM   #3
DIY'er
jamiedolan's Avatar
How do you check the winding?, can I measure the resistance on it with a meter?
I attempted to bypass the humidstat by jumping the wires.
Jamie
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 05:49 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 01:02 AM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 07:49 PM
