Old 02-03-2013, 01:57 PM   #1
Aprilaire 760 with RP 425 manual humidistat
I just moved into a new home and there is an existing installation of Aprilaire 760 humidified with RP425 manual humidistat. The humidifier is wired to humidistat only and will turn on regardless of whether the furnace is on or off based on humidity only. I would like to wire the humidifier so it only turns on when the furnace is on. The blower only runs when the heat is on so it would be ok to wire it so the humidifier is on when the blower is on. Since the Aprilaire 760 has its own power supply I am not sure how to wire the circuit so it would be open when the blower was off. I have a Lennox furnace with 20J8001 board. Thank you very much for your help.
agavrilo is offline   Reply With Quote
Old 02-03-2013, 02:02 PM   #2
Some diagrams at this site:
http://www.alpinehomeair.com/viewcat...categoryID=213
diyorpay is offline   Reply With Quote
Old 02-03-2013, 02:15 PM   #3
Unfortunately they don't answer my question. Is there a way without a current sensing relay?
Old 02-03-2013, 02:18 PM   #4
An old Tradesmen
Need a relay of one type or another. That is energized by the blower, or a W call.
Old 02-04-2013, 10:39 AM   #5
Thank you all for your help.
Aprilaire 700/Carrier Humcclfp1318 not starting Ahavis HVAC 11 11-24-2012 07:26 AM
Replacing an Aprilaire model 58 Humidistat with a model 60 Sino HVAC 3 01-25-2012 08:39 PM
Humidistat manual settings question detyianni HVAC 8 01-12-2011 10:49 PM
Is this Aprilaire digital humidistat working right? Studly HVAC 6 03-17-2009 04:29 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 08:49 PM
