Aprilaire 700A On Goodman Furnace? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 03:38 PM   #46
Rewards Points: 552
Originally Posted by xnaron View Post
Hi,
Did you get a template for cutting the hole in the duct for the 700? The documentation makes reference to a template. Is this something they provided in the box or do I need to make it myself?
thanks,
Brendin
The large install sheet IS the template.
kcrossley2 is offline   Reply With Quote
Old 02-07-2012, 10:37 AM   #47
Kcrossley2 - Which way did you end up wiring your 700? Did you use the Goodman-preferred method or method 1 from the posted diagram shared on page 1?
Just purchased the same model and am preparing for a similar install on a Goodman furnace. Thanks in advance for your help.
Zrelaxed is offline   Reply With Quote
Old 02-07-2012, 10:47 AM   #48
Rewards Points: 552
Smile
Actually, I ended up having it professionally installed—for two reasons.
1. Furnace electronics are expensive and I didn't want to damage anything.
2. Installing it yourself voids the 5-year warranty.
If you go the same route as I did get a price upfront and make sure it's from a respectable HVAC company. Also, make sure the tech explains exactly what he's going to do BEFORE he does it. Remember, there is some cutting involved and once he makes a big hole that's it. I also told my tech that neatness counts so he knew my expectations were pretty high. I couldn't be happier with that decision even though it cost me about $400 for the install. And finally, make sure you register your unit with Aprilaire for warranty purposes. Good luck!
Old 02-08-2012, 05:46 PM   #49
All good advice - much appreciated. I'll continue to research the 'best' way to wire my humidifier
Old 02-18-2012, 04:39 PM   #50
I was wondering how big of a house the Aprilaire 700 can handle?
scourtney is offline   Reply With Quote
Old 02-18-2012, 04:41 PM   #51
if it's not in this thread u can google it.
hvac5646 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 09:00 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 03:29 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 01:47 PM
