Aprilaire 700A On Goodman Furnace? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 09:32 AM   #16
Rewards Points: 556
Another question. Can I tie in the humidifier drain on the Aprilaire 700 to the HVAC condensate line that runs outside or will it freeze? Also how much excess water does the humidifier generate?
kcrossley2 is offline   Reply With Quote
Old 01-08-2011, 09:40 AM   #17
Rewards Points: 496
I'm told that this unit gives off significant waste water and venting with condensate is not good. It could freeze and backup.
The 700 feeds twice as much water as the 600, for larger homes.
http://www.alpinehomeair.com/related...0Sheets.09.pdf
You will need a pump.
Mine's attached.
Condensate and waste humidifier water drip into pump. Pump float determines when to pump thru plastic tubing to an indoors drain.
From your original pics, I'd take pump tubing thru wall next to garage door and over to sink drain. Where you have a nice tee connection with the gauge right above it, I'd swap out the tee with a plactic tee for kitchen sink that accommodates a dishwasher. It's a tee with a y branch. I'd push the tubing feed from pump onto that.
Edit: Instead of tee, it's the fitting just below tee. Straight piece but one for adding a dishwasher discharge.
[IMG]file:///E:/Cake%20B-Sides%20and%20Rarities/P1010552.JPG[/IMG]
diyorpay is offline   Reply With Quote
Old 01-08-2011, 09:56 AM   #18
An old Tradesmen
Rewards Points: 7,256
How big is your house that you need a 700?
Old 01-08-2011, 11:02 AM   #19
Rewards Points: 556
Originally Posted by beenthere View Post
how big is your house that you need a 700?
3800 sf
Old 01-08-2011, 11:03 AM   #20
Rewards Points: 556
Mine's attached.
The instructions say nothing about a pump. About how much water does this thing use? Water in our county is pretty expensive.
Old 01-08-2011, 12:11 PM   #21
An old Tradesmen
About 6 gallons per hour of its run time.
Old 01-08-2011, 12:23 PM   #22
Rewards Points: 556
If that's the case, I clearly have to tap into the household drain.
I was also considering the purchase of a TrueSteam humidifier, but the additional cost of electricity would probably negate any water savings.
Old 01-08-2011, 12:28 PM   #23
An old Tradesmen
The tighter you seal your home. The less the humidifier has to run.
Old 01-08-2011, 12:48 PM   #24
Rewards Points: 556
It's a new home so it SHOULD be pretty tight, but with this builder, who knows?
Old 01-08-2011, 02:21 PM   #25
Rewards Points: 496
Instructions don't mention a pump because they assume a basement drain is available. When no drain is available, it has to be pumped to the nearest waste pipe. In my case, it was the drain for washer. The washer is used often so any acidic discharge from the furnace condensate doesn't have a chance to eat pipes. It's the acidity of Coke and it eats pipes. Hmmm.
Old 01-08-2011, 04:04 PM   #26
An old Tradesmen
Lots of new homes aren't tight.
If your home is truely tight. Then you need a fresh air intake/ERV/HRV for your home.
Old 01-08-2011, 04:19 PM   #27
Rewards Points: 556
Okay, I just finished wiring everything up. The furnace is working and so is the outlet and transformer. The only problem is my transformer is suppose to have an output of 24V AC, but according to my multimeter it's reading 28.4V AC. Is that normal?
Thanks!
Old 01-08-2011, 04:22 PM   #28
An old Tradesmen
Yep. it is.
Old 01-09-2011, 06:09 AM   #29
Rewards Points: 556
Here are photos of the new outlet I added to my furnace. This will provide 120V power to the Aprilaire 700 fan. The device mounted on top of the metal outlet box is the 24V transformer that powers the humidifier. Aprilaire started including these because I think a lot of people who were trying to pull power from their furnace computer board were blowing it.
Today, I'm tapping into the hot water heater with the Shark Bites that Hixheat1 recommended.
Old 01-09-2011, 08:31 AM   #30
An old Tradesmen
Think i would have put the recep on the outside of the furnace.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 09:00 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 03:29 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 01:47 PM
