Aprilaire 700 Wiring Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 07:46 PM   #1
I am installing an Aprilaire 700 to a Ruud UHBK handler. I was going to wire the digital humidistat R&C terminals to the W1&C at the handler. I saw it wired this way on a Trane air handler with a similar humidifier. One of the diagrams for the Aprilaire showed this wiring as the preferred method. Then I would plug the fan from the humidifier to an ac outlet nearby. Would this setup supply the correct voltage and operate the humidifier when there was call for heat?
carlb7 is offline   Reply With Quote
Old 11-17-2010, 08:42 PM   #2
R and c get a constant 24 from a transformer to powrr backlight, is this the newest #60 control? if its the 58 control, for your air handler/ heatpump put w/g from humidistat to g on board. and cf to common on board.
JJDH is offline   Reply With Quote
Old 11-17-2010, 09:21 PM   #3
Not sure which model yet. I will receive the humidifier from shipper soon. I'll follow your instructions if its the #58.
Old 11-22-2010, 02:52 PM   #4
Finally my humidifier has arrived!! I have the model 58 digital controller. As stated the R & C get constant 24 from transformer but could you explain further on that?
Aprilaire 58 Wiring schematic.pdf
Old 11-23-2010, 04:45 PM   #5
Could anyone guide me on this? I was hoping to install the humidifier tomorrow. I wasn't sure if I wire R & C and G & C ?
Old 11-23-2010, 06:13 PM   #6
newtech's Avatar
Rewards Points: 164
Check post #2
newtech is offline   Reply With Quote
Old 11-23-2010, 08:20 PM   #7
Thanks newtech. Post #4 explains that I am not quite sure about R & C getting the constant 24 from the transformer. Post #5 is asking for further explanation. I was hoping for a little more help.
Old 11-24-2010, 10:00 AM   #8
Could I please get clarification on the R & C wiring? Do I wire the R to R on IFC board in air handler, C to C on IFC board, W/G to G on IFC board and C/F to C on IFC board?
Old 11-25-2010, 02:05 PM   #9
I finally learned from a friend of mine in the HVAC business on the correct wiring. I thought this forum was designed to help the DIY'er. I'm not sure what was wrong with my question. Maybe I will have better luck next time.
Old 11-25-2010, 03:59 PM   #10
An old Tradesmen
Rewards Points: 6,464
You got the answer to your original question.
Not all threads get 100's of replys.
Old 12-09-2010, 04:40 AM   #11
An old Tradesmen
Nice spam you posted Lee.
I see you used a different name here, then on that other site.
Question about AFCI and Ontario code as well as some other general wiring queries drunken0monkey Electrical 5 06-15-2010 10:49 AM
Yet another subpanel wiring question Chris_M Electrical 6 06-10-2010 06:12 PM
carrier 48ss-042 wiring Question bekind42 HVAC 3 06-15-2009 06:54 PM
Older wiring question... PirateKatz Electrical 8 11-25-2008 11:11 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
