AprilAire 700 Wiring On Old Furnace??? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 04:49 PM   #16
AKA HVACTECHFW
Rewards Points: 1,208
You have it wired wrong if humidistat does not stay on 24/7. I think you have your transformers going to the wrong components. R and C from furnace control go to R and C on humidistat and should show power 24/7. Transformer from EAC terminals should be in humidifier circuit connected through HH terminals as depicted in the diagram.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-19-2012, 05:27 PM   #17
raylo32's Avatar
Rewards Points: 1,282
There are several ways to wire this beast up. Mine is wired per the manual below... see the 700A (automatic h'stat) diagram. For the "24vac accessory terminal" connection I just use the W1 on the furnace board. This energizes the humidifier on call for heat.
With the xfmr wired like this the stat will always be on. You can hard wire the xfmr to the 120V power inlet box in your furnace or get a plug-in xfmr and mount near the stat. I chose the plug-in method since I have a handy receptacle near where I mounted the stat.
http://www.discounthumidifiers.com/v...structions.pdf
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-19-2012, 07:50 PM   #18
Well... All is hooked up according to the first diagram, but still no worky. No blower fan either so I suspect something else is going on. Time to eat crow and call in a pro. Thanks for the time and help everyone!
ryker99 is offline   Reply With Quote
Old 10-19-2012, 10:01 PM   #19
An old Tradesmen
Rewards Points: 7,278
The control is suppose to be powered from the transformer that came with it. Specially since the HH terminals get their power from the R and C terminals. Wiring it the way you did, may have caused problems.
Old 10-19-2012, 10:20 PM   #20
AKA HVACTECHFW
I thought HH were dry contacts?
IT IS WHAT IT IS
Old 10-19-2012, 11:11 PM   #21
An old Tradesmen
Nope, not on that control. Look at the Aprilaire wiring diagram.
Old 10-19-2012, 11:34 PM   #22
AKA HVACTECHFW
http://www.ntsupply.com/files/products/60wiring.pdf
I did and it shows dry contacts.................
IT IS WHAT IT IS
Old 10-20-2012, 07:46 AM   #23
An old Tradesmen
Old 10-20-2012, 08:32 AM   #24
AKA HVACTECHFW
I love how aprilaire's own documents show it 2 different ways. Per what the model 60 control instructions show they are dry contacts. Per what the 700A instructions show they are live.
I just noticed that the 700A instructions show a different humidistat all together with different connections....
OP, which humidistat do you have? What terminals match your humidistat?
IT IS WHAT IT IS
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 04:33 PM
Trane gas Furnace wiring issue Praetor HVAC 6 08-13-2012 07:31 AM
Wiring Aprilaire 700a to Honeywell EIM and Furnace mk5tdi HVAC 9 03-09-2012 05:19 PM
Old furnace fan blowintg 24/7. Wiring question. grantb5 HVAC 16 09-28-2011 10:49 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
