AprilAire 700 Wiring On Old Furnace??? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 08:57 PM   #1
AprilAire 700 wiring on old furnace (with pics)???
Hi Folks.... longtime lurker, first time posting!
I just replaced an old wheel "sears" humidifier off my old Carrier Super Saver furnace that is nearly 25+ years old. Furnace is in good condition, but I wanted to replace the old humidifier. I picked up an AprilAire 700 and installed it just fine.... except that pesky wiring.
I'm looking for some help on what exactly to do.
I've got the supplied transformer wired to constant 120v power. The plug to the unit is also wired to constant 120v power. Now... where do all those colored wires go!! Any assistance would be much appreciated. Thanks for your time...
Here's the furnace control board:
Here's the transformer that I have installed:
Here's the humidstat automatic controller 700:
ryker99 is offline   Reply With Quote
Old 10-19-2012, 05:16 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
This is how it should be wired. I have left out the G and Gf connections because I believe that the humidifier should ONLY run with a call for heat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-19-2012, 05:16 AM   #3
An old Tradesmen
Rewards Points: 7,362
HH to the humidifier, R and C to the transformer you installed, C to furnace common, and W/G to the W terminal of the furnace.
The install manual should have all of this in it.
Old 10-19-2012, 06:12 AM   #4
Thanks for the help "beenthere" and "hvactech126". Looking at your responses, they don't seem to both align, unless I'm reading it totally wrong.
hvactech126 has R and C to humidstat, where beenthere has R and C to transformer....
When I ripped out my old sears humidifer, the EAC-1 and EAC-2 were both used, so looks like havactech126 makes the most sense based on previous wiring.
Thanks again for the help.
Old 10-19-2012, 06:31 AM   #5
Okay... studying this diagram now... I've currently got transformer hooked up to constant 120v power. I need to remove that and install the transformer to the EAC-1 and EAC-2 on the board. Does it matter if black or white go to which EAC?
Old 10-19-2012, 08:36 AM   #6
AKA HVACTECHFW
You are correct. And no it does not matter which lead goes to each terminal.
IT IS WHAT IT IS
Old 10-19-2012, 09:55 AM   #7
Okay. just hooked it up exactly as your diagram says and now I have no power to the transformer. So, either I smoked the board or the transformer during my frivolous wiring exercises the other day.
Old 10-19-2012, 10:12 AM   #8
AKA HVACTECHFW
The fan must be running in order for the transformer to be powered.
IT IS WHAT IT IS
Old 10-19-2012, 11:20 AM   #9
Okay. And if the humidstat isn't even powered on then it's a furnace board fail? The exhaust fan does work though on the furnace.
Old 10-19-2012, 12:31 PM   #10
raylo32's Avatar
Rewards Points: 1,284
To be operable to display humidity that digital humidistat needs to be powered with 24vac whether the furnace is running or not. I used an external plug-in 24vac transformer instead of hardwiring one for my Aprilaire 700.
The wiring diagram you are using is probably from one that used the old manual humidistat that did not require 24vac to operate and had no digital display. So if you want yours to display when the furnace is off you will need to either hardwire the xfmer to a constant 120v source or get a plug-in external like mine. Having said that I think it would still work OK like you have it, the stat just would be de-energized and have no readout when the furnace is off.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-19-2012, 01:05 PM   #11
Okay.... if I go back and wire in the thermostate to constant 120v source, what do I do with the EAC-1 and EAC-2 terminals on the furnace board?
Old 10-19-2012, 01:18 PM   #12
AKA HVACTECHFW
If you wired according to my diagram then the humidistat should be powered 24/7 from the R and C terminals on your control board in the furnace. The indoor blower must be running in order for the humidifier to actually run.
IT IS WHAT IT IS
Old 10-19-2012, 01:22 PM   #13
I've done it exactly. What are thoughts on what is wrong? I do appreciate the continuous feedback!!
Old 10-19-2012, 02:34 PM   #14
AKA HVACTECHFW
Check for 24vac @ R and C on the furnace control board and at the humidistat.
IT IS WHAT IT IS
Old 10-19-2012, 03:22 PM   #15
okay... 24v checked out perfect at board, transformer and humidstat.
Checked the EAC terminals and 0v. Blower did not turn on. We had ignition, flame and exhaust fan all worked.
So... now what??
Also, is there a way where I can wire for the humidstat to be constantly on? Humidstat turns on and off with furnace kick on.
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 04:33 PM
Trane gas Furnace wiring issue Praetor HVAC 6 08-13-2012 07:31 AM
Wiring Aprilaire 700a to Honeywell EIM and Furnace mk5tdi HVAC 9 03-09-2012 05:19 PM
Old furnace fan blowintg 24/7. Wiring question. grantb5 HVAC 16 09-28-2011 10:49 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
