Aprilaire 700 Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 11:53 AM   #1
I recently swapped out an older Aprilaire 700 (manual mode) humidifier for a new Aprilaire 700 series. I tried using the humidistat from the old one, but the new one didn't work off of it, so I installed the new humidistat. I get 24V from the furnace to the humidistat, but was not getting any voltage out of the "H" terminals, so--after a good bit of hesitation (the wiring diagram with the unit is not great)--I connected another 24V transformer to a 110 line to feed 24V between the "H" terminals and the humidifier. The humidifier comes on when I force it on using the "test" mode, but it stays on after that. The control mechanism in the humidistat does not appear to be working, because the humidifier does not come on with the furnace. Any help with this situation would be much appreciated!
tysonmj is offline   Reply With Quote
Old 01-30-2011, 06:58 PM   #2
For those in the same situation, two 24V connections are required -- one to the humidistat for constant power, and the other--via the transformer provided with the unit--between the humidistat and the humidifier. That said, in manual mode, another connection between the "W" terminals in the furnace and on the humidistat is required for the humidifier to recognize when the blower trips on (and off).
Old 01-31-2011, 05:48 PM   #3
referenced previously on this site:
http://www.alpinehomeair.com/viewpro...ions_brochures
http://www.alpinehomeair.com/related...20Diagrams.pdf
diyorpay is offline   Reply With Quote
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 04:33 PM
Aprilaire 700 humidifier wiring installation seanbie HVAC 10 12-17-2011 04:13 PM
Aprilaire 700 Wiring Question carlb7 HVAC 10 12-09-2010 03:40 AM
Aprilaire 700a wiring issue bman2448 HVAC 1 12-29-2008 11:48 PM
Wiring AprilAire 600 to Bryant FB4ANF042 PartyLike1899 HVAC 1 12-11-2007 11:55 PM
