Aprilaire 600m Humidifier Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 04:00 PM   #16
Amateuralex's Avatar
Rewards Points: 270
Originally Posted by Dave Sal View Post
I just looked at their FAQ's myself and didn't see that. Which FAQ question number was this mentioned on? Before I had my old control panel replaced I could get the humidity pretty much where I wanted it. I would normally keep it around 48 relative humidity but would lower it a bit if the outside temps dropped significantly to reduce the condensation issue. I disagree with the recommendation of 35 RH when it's 20 degrees outside. At that level I would be getting shocked from static electricity, the wood in the home would dry out and crack, skin gets dry and cracked, and viruses would thrive better than at 48 RH, which appears to be the sweet spot as far as health is concerned.
Hey there.
Answer 2) at http://www.aprilaire.com/index.php?z...ct=Humidifiers.
How do I know when my Aprilaire bypass humidifier is operating?
If the humidity in your home is 45% or higher your Aprilaire bypass style humidifier will not run. This is because this the highest humidity level our humidifierís will attempt to attain. If you turn your humidistat from 15% to 45% and the humidifier does not run this is verification the humidity in your home is above 45%. Once the humidity level drops below 45% your Aprilaire bypass style humidifier should operate anytime the furnace is producing heat and the indoor relative humidity is less than the humidification set point on your humidistat. If not, we recommend contacting your installing contractor to troubleshoot the humidifier at your home.
Amateuralex is offline   Reply With Quote
Old 01-07-2013, 04:10 PM   #17
Dave Sal's Avatar
Rewards Points: 592
Amateuralex
Thanks for the info. My humidity has been hovering around 46% which is quite comfortable for this time of year. As long as it stays in that general range I am satisfied.
Dave Sal is offline   Reply With Quote
Old 01-07-2013, 04:14 PM   #18
Rewards Points: 270
Amateuralex
I agree, sounds good.
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 05:26 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Aprilaire 700A Humidifier - Automatic control question feign3 HVAC 1 12-11-2007 05:31 PM
Aprilaire Humidifier ffgus HVAC 4 02-05-2007 05:04 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 08:49 PM
