Aprilaire 600m Humidifier Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 02:04 PM   #1
Dave Sal's Avatar
Rewards Points: 716
Aprilaire 600m humidifier problem
Back in the fall of 2010 I had my local HVAC guys install an Aprilaire 600M humidifier on my Lennox G60 two stage furnace. It worked great until the beginning of this heating season when I noticed that the air was getting dryer and dryer each day. (I use a calibrated Taylor hygrometer to monitor the humidity). I then checked and found that the humidifier wasn't turning on. Called the HVAC guys back and they found that the humidistat control panel was bad and replaced it. Before this problem came up, I used to keep the humidistat at about 35, which would result in an indoor humidity of between 45-50, which is very comfortable. After the new control panel was put in, the humidifier works but unless there's cooking on the stove or people showering the humidity doesn't seem to be able to go above 45, even though I almost have the control maxed out. Is there an adjustment (other than the dial) that controls the sensitivity of the control panel? If not, I'll probably have to have them come back and replace this one. I may have problems with a warranty claim though, cause it still technically works. Thoughts?
Dave Sal is offline   Reply With Quote
Old 01-04-2013, 02:44 PM   #2
Experienced HVAC Tech
HVAC1000's Avatar
It could be that not enough water is going to the humidifier. Try to open the water supply anymore than it is
HVAC1000 is offline   Reply With Quote
Old 01-04-2013, 03:38 PM   #3
Dave Sal's Avatar
Rewards Points: 716
Thanks for the reply. The saddle valve is open as far as it can go.
Old 01-04-2013, 04:09 PM   #4
Rewards Points: 484
The new control may be calibrated different then the old one, I had the same one with mine and it was way off. My indoor humidity was only around 30% but the manual control had to be set between 40 and 45% to keep it there.
sammy37 is offline   Reply With Quote
Old 01-04-2013, 04:17 PM   #5
Dave Sal's Avatar
Rewards Points: 716
Sammy37, thanks for the reply. That's kind of what I assume is the case here. Were you able to modify the settings or did you simply crank it up higher than normal?
Old 01-04-2013, 04:43 PM   #6
Rewards Points: 484
I bought a White-Rodgers thermostat that has a humidity function built into it, works much better.
Old 01-04-2013, 05:19 PM   #7
Dave Sal's Avatar
Rewards Points: 716
Thanks. I'll probably end up buying a new one, as I found the identical model on Amazon for just over $30. Not bad.
Old 01-04-2013, 05:37 PM   #8
HVAC Tech/ Browns Fan
Did you even check the water flow out of the black feed tube to the pad? Even if you turn up the water valve is not going to work if the orfice is plug up. Look at the valve and you will see the black tub going off to the side to the pad. Undo that and look at the orfice. You may need a very small wire to rhem the hole
Tator1076 is offline   Reply With Quote
Old 01-04-2013, 05:44 PM   #9
Dave Sal's Avatar
Rewards Points: 716
Tator1076, I change the filter once a year even though it still looks new. There's plenty of water coming out of the discharge tube into the sink as well, but I'm going to pop the cover just to be sure. You never know if a piece of sediment or something clogged up a tube. Thanks for the suggestion.
Old 01-04-2013, 06:08 PM   #10
Is the by pass damper 100% open?
Old 01-04-2013, 06:11 PM   #11
Dave Sal's Avatar
Rewards Points: 716
Yup, first thing I checked.
Old 01-04-2013, 06:20 PM   #12
Rewards Points: 484
Easiest way to clear up all this guesswork, is the humidifier running? If you have the dial maxed out and it's not running but your indoor reading on your hygrometer is low, than it should be plain and simple that the new humidistat is just way off.
Old 01-05-2013, 10:40 AM   #13
Rewards Points: 508
I believe with steam type, to really max out humidity, pros seem to prefer hot water feed over cold.
Would this work for this type too? Or would hot water dry out filters quicker?
Also, looks like a manual humidistat. Probably gives you more control, if you're home a lot. Comes in auto model which considers outdoors temp etc and makes programmed adjustments.
diyorpay is offline   Reply With Quote
Old 01-07-2013, 02:19 PM   #14
Amateuralex's Avatar
Rewards Points: 270
I've been researching humidifers to prepare to install my own, and I just read the FAQ at Aprilaire's site, and it says that their humidifiers won't go past 45 RH.
Amateuralex is offline   Reply With Quote
Old 01-07-2013, 02:47 PM   #15
Dave Sal's Avatar
Rewards Points: 716
I just looked at their FAQ's myself and didn't see that. Which FAQ question number was this mentioned on? Before I had my old control panel replaced I could get the humidity pretty much where I wanted it. I would normally keep it around 48 relative humidity but would lower it a bit if the outside temps dropped significantly to reduce the condensation issue. I disagree with the recommendation of 35 RH when it's 20 degrees outside. At that level I would be getting shocked from static electricity, the wood in the home would dry out and crack, skin gets dry and cracked, and viruses would thrive better than at 48 RH, which appears to be the sweet spot as far as health is concerned.
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 04:26 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Aprilaire 700A Humidifier - Automatic control question feign3 HVAC 1 12-11-2007 04:31 PM
Aprilaire Humidifier ffgus HVAC 4 02-05-2007 04:04 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 07:49 PM
