Aprilaire 600M Humidifier Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2013, 11:11 PM   #1
Dave Sal's Avatar
Rewards Points: 600
Aprilaire 600M humidifier not working
Hey guys,
I have a three year old Aprilaire 600M humidifier mounted on the cold air return. The water supply is connected to the hot water line of the water heater with a saddle valve. Last year at this time the humidifier wasn't working. Had the HVAC guy come out and he found that the saddle valve was clogged with white particles, apparently from the water heater. He changed it and it worked perfectly for the rest of the heating season. I just turned it on again for the new heating season and it worked for the first couple of days. Today I noticed it was getting a bit drier than usual and checked the humidifier and it's not working. I'm guessing that the saddle valve is clogged again. My question is what would be the best way to connect the water supply to the hot water line. Saddle valves seem cheap and prone to fail or leak. There's got to be a better way. Any suggestions?
Dave Sal is offline   Reply With Quote
Old 10-28-2013, 05:36 AM   #2
An old Tradesmen
Rewards Points: 6,548
Tee off hot water line with a 3/8" line, install valve, then reduce to 1/4" for water heater.
Old 10-28-2013, 06:28 AM   #3
Rewards Points: 582
yep cut into waterline with a tee .we use 5/8 od x 3/8 od compression valve then use 3/8 x 1/4 reducer for humidifier....ben sr
Old 10-28-2013, 09:40 AM   #4
Dave Sal's Avatar
Rewards Points: 600
Thanks for the replies guys. That sounds like the way it should have been done in the first place.
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 07:30 PM
Air Exchanger and Humidifier Zombify HVAC 0 05-11-2010 12:38 PM
Aprilaire 700A Humidifier - Automatic control question feign3 HVAC 1 12-11-2007 05:31 PM
Aprilaire Humidifier ffgus HVAC 4 02-05-2007 05:04 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 08:49 PM
