Aprilaire 600A And Carrier Furnace-Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2009, 01:33 PM   #1
Aprilaire 600A and Carrier Furnace-Wiring
1. Yellow wires from solenoid are going to "H" circuit on humidistat
2. "HUM" on furnace circuit board is going to W/G on humidistat
3. "COM" is going to C/f on humidistat
What's next....how should I power this up..I understand there are different options...what's the preferred method (24v from furnace...no need for transformer...correct?)
rpl47 is offline   Reply With Quote
Old 01-02-2009, 01:40 PM   #2
Need to know if your furnace has powered humid terminals an whether they are 24v or 110v
hvaclover is offline   Reply With Quote
Old 01-02-2009, 01:42 PM   #3
Yes, powered HUM terminals 24v
Old 01-02-2009, 01:53 PM   #4
Wire the humidistat to one lead of solenoid and wire other side of humidistat to hot terminal of humid terminal on furnace. (24v to ground)
Wire the the remaining wire of humidifier solenoid back to common terminal of furnace humid terminal.
This is assuming your humidifier is 24v.
